Author Topic: LSD diff oil  (Read 1998 times)
psnimv6
  • tyrone n ireland
LSD diff oil
« on: 21 September 2007, 20:56:36 »
hello all just a quick question i ordered lsd oil for main dealers and when i when to collect it was just a small bottle ( a additive ) i am right in thinking that all i need to do is add this to any quaility sae90 hypoid oil?as the dealers have no idea as usual any advice much appreciated
sassanach
  • trowbridge
Re: LSD diff oil
« Reply #1 on: 21 September 2007, 21:00:01 »
correct, empty the bottle into the diff and fill with sae90
psnimv6
  • tyrone n ireland
Re: LSD diff oil
« Reply #2 on: 21 September 2007, 21:06:42 »
thanks for that i will collect tommorrow from the main dealers and top up my diff as it has a small leak and do not want to run it low of oil thanks
Re: LSD diff oil
« Reply #3 on: 21 September 2007, 21:12:28 »
Hmmmm.....you need more than one bottle for the LSD.....I recommend BOA90LS from opie oils, its good oil and has the additive already in it.
psnimv6
  • tyrone n ireland
Re: LSD diff oil
« Reply #4 on: 21 September 2007, 22:02:05 »
the dealers when i ordered the what they said was 1 litre of oil so i assume it was enough additive for 1 litre is what it meant to mix to maybe but i ordered 2 bottels anyway so do you think this should be enought thanks for your interest
psnimv6
  • tyrone n ireland
Re: LSD diff oil
« Reply #5 on: 22 September 2007, 13:28:27 »
being to dealers today and collected additive (50ml)as usual they do not no how much to put in to 1 litre of oil  do any of you no if this is enough to mix in to 1 litre of 90 oil as i really need to top up my diff thanks in advance
Re: LSD diff oil
« Reply #6 on: 22 September 2007, 19:34:01 »
Its 3 parts 90 hypoid to 1 part additive......hence why I use BOA90LS....its MUCH cheaper.
psnimv6
  • tyrone n ireland
Re: LSD diff oil
« Reply #7 on: 22 September 2007, 21:51:42 »
thanks for the reply i checked today and it only needed about 250 ml of oil to fill up to the top so it should not be to bad i put one 50 ml bottle in to the 1 litre bottle,so in that case i will try and get the other 50 ml bottle directly in to the diff , do you think this would be ok , and then at the next service (5k),i will buy the oil you said and do a diff oil change at the same time as it will be due a change as the milage will be 41000 and as said on here it will need changed at 50000 so it will do no harm anyway thanks again mark dtm
