Author Topic: steering column stalks  (Read 1197 times)
gsxmax1
  • Wilts/Som/Dorset Border
« on: 23 September 2007, 21:03:14 »
can you get at / change the steering columns stalks without removing the steering wheel to undo the two screws behind the wheel that hold the upper and lower parts of the column shroud together?
cheers for any info
max
Dazzler
  • Haverhill, Suffolk
Re: steering column stalks
« Reply #1 on: 23 September 2007, 21:05:00 »
Yes, just turn the wheel and you should see a little plastic cover over the screw, pop this off and away you go. You will have to then turn the wheel 180 to get to the other one. HTH.
« Reply #2 on: 23 September 2007, 21:05:34 »
Yes, steering wheel does not need to come off.
Just turn wheel to access those 2 screws...
gsxmax1
« Reply #3 on: 23 September 2007, 21:09:09 »
Thanks folks for the quick replies.
i'll give it a try
my initial view was that due to the size of the steering centre (with air bag and radio buttons) it would not be as easy/possible as the old cavalier was.
cheers
max
