Author Topic: Smell probleem and RPM  (Read 2041 times)
Explorer
« on: 24 September 2007, 02:57:14 »
Hi every one ..
i will post 3 probleems that hapeend to my V6 omega
1- When i start the engine , the rpm jump to 1500 rpm or value less than 2000 and start going down normally within seconds to the normal case at 600 rpm , it is rarly happen but it happen
2- Sometimes whem i park my car or waiting , the rpm going down fastly from 600 to 400 rpm without any other probleem.
3-when i drive my car on 140 KM/h or more , a bad smell similar to a burning oil is come out and it is dissapear as soon as i slow down the speed .. what is the probleem and is it safe and can fire start soon as i ignore the probleem ?
Thanx to be paitent
« Last Edit: 24 September 2007, 05:03:08 by Explorer »
Tafty
  • Liverpool
  • This week I am no longer the owner of a miggy!! :(
Re: Smell probleem and RPM
« Reply #1 on: 24 September 2007, 06:25:27 »
Hi and welcome to the forum,
sounds like you may have a fuel filter problem - very easy and cheap to replace.
As for the smell of burning oil, could be a couple of things, do you have an Automatic- as it may be the gearbox vent hose touching the hot engine - is usually tied to the pipes at the rear of the plenum - needs to be left open.
The breathers may need cleaning out and forcing a leak at the cam covers - when were they last done - if never check the maintenance guides on how to do it.
Others will be along later with more pointers for you.
cheers
lee
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 24 September 2007, 08:53:24 »
Yep as said, clean out the breathers and also clean the IACV. Oil smell is more than likely to be the cam cover gaskets so these will need replacing. All these items are covered in the maintainance guides ;)
Danny
  • Wigan, Greater Manchester
« Reply #3 on: 24 September 2007, 08:53:57 »
for 1 and 2, could it just be that the idle control valve, throttle body and breather pipes need a good clean?
Explorer
« Reply #4 on: 24 September 2007, 10:34:54 »
Thanx for all of u
i went to the maintanice today and the guy there tell me to replace the mass flow sensor since he had clean it before and nothing change
about the smell , he told me that it is normlly hapeend due to enigne hottness which lead to a oil vapour that drops on hot thing and make that smell
and advise or comments plzzzzzzzz
Dazzler
« Reply #5 on: 24 September 2007, 12:11:59 »
I would try what we have said first as that is the first port of call......You must clean out the IACV first before you start spending lots of money on what one garage has said.
JasonH
« Reply #6 on: 24 September 2007, 12:17:58 »
Clean the Idle Air Control valve - very common problem.
Take some of the spark plug leads off the spark plugs and see if there is oil on them. If you have then the hot oil smell is due to leaking cam cover gaskets (also very common).
geoff
  • thornaby,stockton on tees
« Reply #7 on: 24 September 2007, 12:39:28 »
like everyone else says ,clean idle control valve and breathers,will almost surtenly be cam cover gaskets leaking oil ,both items are common thing on omega v6's and on the 4 cyclinders,but please try and use genuine vx gaskets as after market ones ar crap,once done though you should not have any probs with gasket :y :y :y
Page created in 0.023 seconds with 20 queries.
