Author Topic: headlamps  (Read 4504 times)
Re: headlamps
« Reply #15 on: 15 September 2007, 22:21:04 »
I didn't think the facelift projector h/lights were different from the pre-facelift projector h/lights?
different shape
davlad22
  • Sunny Yorkshire
Re: headlamps
« Reply #16 on: 17 September 2007, 17:23:04 »
Me and The Boy have got a bit of a thing running with the legality and practicalities of aftermarket HID headlights  ;)
Facelift into prefacelift? Physically I don't think they will fit very well  :-/ One of the main differences is that facelift has washers in the bumper and pre has washers set in the panel below the lights.
Personally I cannot recommend Philips 50% 'Vision Plus'  :( Lots of glare for traffic in front and not much improvement.
I've commented on this too many times anyway, my HID's are great and don't cause any glare. I would only have them fitted in projector lights though.
« Last Edit: 17 September 2007, 17:23:45 by davlad22 »
Rebel1
Re: headlamps
« Reply #17 on: 24 September 2007, 22:19:49 »
Have been using Philips Vision +30% (when that was the best they did) and +50% for many years, change them every 12 monthts, and can report they are much better than standard bulbs. (application: 1999 my with projector lamps).  They do create a bit of glare for the car in front, but in normal circumstances I have the headlamp levelling switch down 1 level, then move them up to the zero setting when someone is hogging the 3rd lane of the m/way even when not o/taking anyone....they get out of the way like Moses parting the Red sea.
What I don't like about the Philips bulbs is that the +80% "X-treme" bulbs aren't available in H1 format, even a year after H4 and H7 came out, and Philips UK advise they aren't likely to bother doing so anytime soon.   >:(
Might move to a good set of aftermarket HIDs, but have the usual problem of the silver reflector being loose within the h/lap (both sides); this is fine with normal bulbs (passes the h/lamp alignment test in the MOT each year), but reckon the weight of the ballast and extra wiring might move the reflector too much, so would have to shell out £100 for a pair of new pattern-part h/lamps off ebay before then buying the HIDs.
Re: headlamps
« Reply #18 on: 24 September 2007, 22:23:25 »
The Hids will glare a bit when they get a bit mucky...
« Last Edit: 24 September 2007, 22:24:10 by TheBoy »
