Author Topic: brake pad sensors  (Read 3841 times)
OMEGA VXR
  • Leicester
  • I love my Omega
brake pad sensors
« on: 21 September 2007, 15:53:37 »
When you disconect the brake pad sensors it should come up on the MID as a fault, but it doesnt on mine!  :(
both the sensors are disconected at the moment cos of painting the callipers so whats gone wrong :question :-?
cheers
[img name=signat_img_resize]http://i159.photobucket.com/albums/t146/WJones_2007/Lee%20Photos/DSCF0113-2.jpg[/IMG]  [img name=signat_img_resize]http://i159.photobucket.com/albums/t146/WJones_2007/Lee%20Photos/DSCF0114-1.jpg[/IMG]
Dazzler
  • Haverhill, Suffolk
Re: brake pad sensors
« Reply #1 on: 21 September 2007, 15:55:37 »
I don't think they do come up on the MID when disconnected....... I think they only come up when the sensor end gets cut by the disc, thus going to earth and bringing on the warning.
« Reply #2 on: 21 September 2007, 16:14:40 »
with yours being a 1994 GLS, i doubt it will display as you will have the TID not MID....
Do you have your radio text at the top or bottom of the display?
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« Reply #3 on: 21 September 2007, 16:23:12 »
as Dazzler says as long as the sensor is in one bit you will not get a fault, all they are is a loop of wire which when the pad wears down causes the loop to contact the earth through the the disc etc and sends the signal back to bring on the warning  :y so you have nothing to worry about they should not be on  :y I would say if you have wear sensors fitted you will have the warning system fitted as they are a fairly expensive item to fit if not being used retail for them is £9.10
« Reply #4 on: 21 September 2007, 16:25:34 »
A 1994 TID does not have the capability to display brake pad warnings, neither will it show oil lack, coolant or any other issues.
AndersH
  • Poole
« Reply #5 on: 21 September 2007, 16:57:27 »
Will a 2000 TID display any of those? As in another thread, I had sensors on my brakes but not sure where it would display if at all...
« Reply #6 on: 21 September 2007, 17:31:22 »
no TID's support brake/coolant/oil issues.
If your radio text eg 'Radio 1' is at the bottom of a 2 part display and on the top section is the outside temp, fuel info ect then it will support other fuctions. If you have the simple 1 section screen it will not.
There are however GID's which are only single layer but are much higher resolution. and support satnav.
TID
MID
« Reply #7 on: 21 September 2007, 18:31:10 »
If the car has wear surely it should have the means of displaying when they're worn through?
LFF64
  • HADDENHAM BUCKS
« Reply #8 on: 21 September 2007, 19:04:13 »
is it not displayed as a warning light on the insturment panel rather than the display
« Reply #9 on: 21 September 2007, 19:44:53 »
Firstly, with the sensor disconnected, it WILL display an error on a MID.  Its a simple system of a loop of wire.  When the pad (and sensor) wears, the loop of wire wears through, breaking the circuit. Nothing to do with earthing through the disks.
As Tunnie quite rightly points out, a TID will not display this - it has no connection to the check control system (which shouldn't be fitted anyway on TID equipped cars).  You need a MID/GID/CID or CCRT700 display to get the warning.  So if all your display can do is radio, time, and temp, you will never get the warning.
Its possible some garage has replaced the pads, and automatically (re)fitted the sensors as well, even though they are not used.
« Reply #10 on: 21 September 2007, 21:36:47 »
nope, graphical display only
Taxi_Driver
« Reply #11 on: 22 September 2007, 13:17:10 »
Just to confuse matters further  ::)
Maybe its only facelifts......but in my handbook.....it clearly shows warning lights under the TID display for brake pads/auto headlamp range/autobox fault   :-/
LFF64
  • HADDENHAM BUCKS
« Reply #12 on: 22 September 2007, 17:54:16 »
Sorry I was not thinking of course its only a loop I should have realised because I loop them out before to clear the fault before and that was only a couple of weeks back  :-[ must be my age  :-/
AndersH
  • Poole
« Reply #13 on: 23 September 2007, 19:23:10 »
That's what I was wondering as mine does display a gearbox error below my TID...
« Reply #14 on: 23 September 2007, 19:25:26 »
Gearbox warning light exists under TID.
