Author Topic: Omega alignment  (Read 7367 times)
rds
Omega alignment
« on: 18 September 2007, 13:12:31 »
Hello everyone
i am having an issue with the main dealer after my 4 year service and alignment problems.
Leaving aside the other issues, they have charged me for an alignment check and adjustment but apparetnly have not adjusted anyting as the car was on the limit of tolerance for pulling to the left!
I was not happy with being charged for this activity/explanation and they are now re-aligning. I have asked that the change be to drive straight ahead ie not pull to the left or right but in a neutral position. The technician has advised me that this would put the geometry to the other extreme tolerance and is not recommended.
Surely if pulling to the left is one extreme, being "neutral" is not the other extreme but mid way to puliing to the right?
They have to sort the car today so any thoughts greatfully received.
many thanks
RDS
    • 530D M Sport, 330i Coupe
Re: Omega alignment
« Reply #1 on: 18 September 2007, 13:52:44 »
Where are you?
If your not to far try http://www.wheels-inmotion.co.uk/ recommended by people on this site.
rds
Re: Omega alignment
« Reply #2 on: 18 September 2007, 13:54:23 »
hi thanks for that - i'm in south London so solihull a bit far!
regards
Re: Omega alignment
« Reply #3 on: 18 September 2007, 13:57:46 »
LOL
Wheels in motion is in Hertfordshire I believe, I didn't make that clear did I!!!!!
« Last Edit: 18 September 2007, 13:58:38 by VXL_V6 »
rds
Re: Omega alignment
« Reply #4 on: 18 September 2007, 14:00:07 »
hoho too quick off the draw i was! apologies.
thing is, car is with the dealer today and i wanted to be prepared for the inevetiable "they are all like that" or what do you expect" type answers.
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
Re: Omega alignment
« Reply #5 on: 18 September 2007, 14:07:19 »
Located in Hemel Hempsted well worth drive to get check, think its best to make an appointment .
Also I think members of this forum get a capped price.
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
Danny
  • Wigan, Greater Manchester
Re: Omega alignment
« Reply #6 on: 18 September 2007, 14:15:36 »
to avoid starting a new thread, can anyone tell me what the most likely cause of inner edge wear would be... on just the offside front tyre?? :-/
all 3 others have worn evenly, my tyre pressures are correct (checked weekly) and the geometry and tracking are "allegedly" spot on according to the guy at my local tracking centre
it's been pulling to the left quite noticeably the last 3 or 4 weeks
its booked in at my local garage, i asked them to check all around the suspension and everywhere to be on the safe side...
any ideas?
Dazzler
  • Haverhill, Suffolk
Re: Omega alignment
« Reply #7 on: 18 September 2007, 15:36:42 »
any ideas?
Camber adjustment is out on that wheel. I had the same on mine, I adjusted the camber myself and all is now well ;)
Danny
Re: Omega alignment
« Reply #8 on: 18 September 2007, 16:18:54 »
any ideas?
easy to do? how would i know when its correct?
Dazzler
Re: Omega alignment
« Reply #9 on: 18 September 2007, 16:33:04 »
I cheated and i must firstly state that this does not mean it will be as good as having it done properly.
Firstly i made sure the car was on a good level surface.
I then via a metal bar that fits the wheel diameter and a spirt level, measured the vertical angle of the good front wheel and the transfered this to the bad one.
The camber on mine is adjusted by undoing the 2 large bolts where the hub assy joins the strut.
The holes are slightly elongated and allow the hub to move in and out, thus altering the camber.
Always mark up with tipex before you adjust as this will give you a refernce mark to make your adjustments from.
It took me about an hour to do, and has worked a treat, no more worn out inner edge :y
Danny
Re: Omega alignment
« Reply #10 on: 18 September 2007, 16:51:38 »
i think i'll seek professional methods for the practical part then :y
thanks :D
wheels-inmotion
Re: Omega alignment
« Reply #11 on: 18 September 2007, 20:25:15 »
Hello everyone
many thanks
RDS
Can you display any figures.... Namely the front camber and castor positions.
JasonH
Re: Omega alignment
« Reply #12 on: 18 September 2007, 21:04:48 »
Pulling to the left on an Omega is often a failed wishbone bush - a VERY common problem.
Pattern wishbones are around £20 each (you should buy a pair and replace both sides) and they come complete with a full set of new bushes. Genuine Vx wishbones are now £180 each (they used to be around £45!).
rds
Re: Omega alignment
« Reply #13 on: 19 September 2007, 11:04:36 »
hi thanks for that - do you think the state of the wishbone bush would have been checked as pasr to fthe MOT or 4 year service that the dealer undertook last week?
also will they have checked tire pressures to ensure that that issue is eliminated re pulling to left?
regards
RDS
jonathanh
  • coventry
Re: Omega alignment
« Reply #14 on: 19 September 2007, 19:36:11 »
Don't think the dealer will check.  4 years ago the dealer warned me about the wishbone bushes as an advisory for the MOT.  THe last three MOTs have passed without even an advisory on this despite me not doing anything at all!
