Author Topic: Oil cooler parts  (Read 3582 times)
Oil cooler parts
« on: 25 September 2007, 20:16:17 »
Hi guys, can anyone please give me the part numbers for the following:
* Oil cooler banjo bolts, 2 of
* Coolant Bridge Banjo Bolts, 2 of
* Coolant Bridge Washers, 4 of
* Oil cooler banjo washers, 4 of
* Oil cooler sealant
Also, what should that little lot cost from the stealer? I have TC.
Cheers :)
James
« Last Edit: 25 September 2007, 20:16:41 by JamesV6CDX »
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Oil cooler parts
« Reply #1 on: 25 September 2007, 20:17:53 »
at work so dont have specifics right now, but those darn hollow cooler bolts are quite dear for what they are....£4 odd each  :(
And my dealer doesnt stock them they had to order them in  :-/
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 25 September 2007, 20:18:22 »
A dumb question but why do you change the banjo bolts????? I thought you only need to change the washers :-/
« Reply #3 on: 25 September 2007, 20:19:10 »
When torquing to 30nm I have often had them snap... hence I only ever fit brand new ones as a matter of course...
Dazzler
« Reply #4 on: 25 September 2007, 20:20:50 »
:o :-? How often????
« Reply #5 on: 25 September 2007, 20:21:53 »
At least twice on an oil cooler one.. and once on a coolant birdge one.
Dazzler
« Reply #6 on: 25 September 2007, 20:29:34 »
Mmmmmmmmmmm...more money ::)
« Reply #7 on: 25 September 2007, 20:33:19 »
Second question... would you fit a genuinely known good but used oil cooler, or would you splash out on a brand new one?
« Reply #8 on: 25 September 2007, 20:56:18 »
The failure mode as I understand it is that poorly maintained vehicles lose the corrosion protection of the coolant due to insufficient coolant changes and the cooler dies so if the cooler is from a known, well maintained car and doesn't show signs of corrosion it doesn't sound unreasonable to re-use it.
Depends on the balance of the cost of the part against the time required to change it.  :-/
« Reply #9 on: 25 September 2007, 20:59:04 »
I can change them in a couple of hours... I think I'll fit the used one...seeing as I have it... and spend the £100 on a cambelt kit instead.
Dazzler
« Reply #10 on: 25 September 2007, 21:02:01 »
I would tend to agree with that/...
« Reply #11 on: 25 September 2007, 21:44:22 »
complete part list, with relevant dealer in stock:
« Reply #12 on: 25 September 2007, 21:47:35 »
I assume the used one is not currently attached to the cooler plate......
I have never broken one of the banjo bolts........
« Reply #13 on: 25 September 2007, 21:53:26 »
Yes it is, but I presume I can jus detatch?
« Reply #14 on: 25 September 2007, 21:56:54 »
Remove it from the plate sooner rather than later, its not unusual for the rear cooler thread to strip when the nut is removed rendering the cooler useless (had this happen twice now!)
