Author Topic: Tuning a 2.6  (Read 5317 times)
Martin_1962
Re: Tuning a 2.6
« Reply #15 on: 25 September 2007, 18:51:24 »
Any ideas anyone?
Unhitch your house from the back...
Re: Tuning a 2.6
« Reply #16 on: 25 September 2007, 19:51:52 »
better spend more money and invest bigger engine..
This is sound advice. Other than the little things like a change to 3.0 cams, chipping, etc. If your tuning gets any more serious than this, your starting point should be the engine that's closest to your requirements off the shelf because every step from then on costs money and takes you into the unknown in some respects. This means the biggest one  ;) unless you need to keep below a certain capacity for some reason or the smaller engine is stronger.
I still think the exhaust is worth playing with, though. A properly designed exhaust will wake the engine up in the midrange.
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Tuning a 2.6
« Reply #17 on: 25 September 2007, 19:59:04 »
Thats all very well for you to say Mr Late model immaculate 3.2  ;) ;D
(check my signature!!!)
Martin_1962
Re: Tuning a 2.6
« Reply #18 on: 25 September 2007, 19:59:58 »
Seems a pity to dump the Y26 when a Y32 is not that cheap - I don't want to spend a fortune - just see what is easy.
Cams - no-one seems to know what is in a 2.6.
I reckon that 200bhp is reachable and affordable.
Long term would be a Y32SE and AR35 transplant but that would be two years away minimum. (when HP finishes)
    • 530D M Sport, 330i Coupe
Re: Tuning a 2.6
« Reply #19 on: 25 September 2007, 20:14:32 »
Good point, if you push the torque figure up I guess you'll increase the stress on the AR25 box (I'm assuming it's an AR25 on a 2.6).
Martin_1962
Re: Tuning a 2.6
« Reply #20 on: 25 September 2007, 20:25:17 »
Pretty sure it is.
As to "why not swap the car?" well I like it and there are not that many cheap facelifts in good condition
Re: Tuning a 2.6
« Reply #21 on: 25 September 2007, 20:36:58 »
Although +20 from the normal is not a far goal the car prices there in your country is comparingly cheap.
just an idea instead of modding, buying a newer healthier bigger engine may be worth..
Martin_1962
Re: Tuning a 2.6
« Reply #22 on: 25 September 2007, 20:38:54 »
Newer car three isn't many and they also have some sily features like no intermittant wipers, two  years time for the Y32/AR35
Re: Tuning a 2.6
« Reply #23 on: 25 September 2007, 20:46:18 »
Personally if I've spent money to buy the car originally, spent lots of time and money getting up to a maintenance level that i'm happy with (serviced regularly, genuine parts, everything working as it should) and therefore feel confident about it's reliability then the last thing I want to do is trade it in so somebody else benefits and then have to start all over again......
For me it's only when a car becomes uneconomic to repair to MOT standard when it's getting older that I would think to change it.
ie. if it was going rotten and two or more other things also needed to be done to get it through.
Just my thoughts!!!
« Last Edit: 25 September 2007, 20:47:31 by VXL_V6 »
Re: Tuning a 2.6
« Reply #24 on: 25 September 2007, 20:49:15 »
The last time I start modding I end up with an unhealthy powerful car  which I spent twice money than its worth
PS: now I dont touch mega other than standard replacements..But even changing sensors make the car more responsive..And I dont plan to sell for a long time also..
« Last Edit: 25 September 2007, 20:51:59 by cem_devecioglu »
Re: Tuning a 2.6
« Reply #25 on: 25 September 2007, 20:50:34 »
That probably didn't end up sounding the way I intended. What I meant is that it doesn't cost any more to start with a 3.2 than a 2.6 and your first 40BHP come for free. Of course if you've already got a 2.6 in your car it's a different matter.
Anyway, my 3.2 is no longer immaculate thanks to a biker who decided to use my front bumper as a safety barrier on a mountain pass in Italy  >:( >:( :'(
Martin_1962
Re: Tuning a 2.6
« Reply #26 on: 25 September 2007, 22:16:59 »
I do have plans when paid for.
3.2 with higher CR, better mounted LPG nozzles
Markjay
  • London
Re: Tuning a 2.6
« Reply #27 on: 25 September 2007, 23:19:14 »
PS: my experience from previous car mod :  better spend more money and invest bigger engine..
'There is no replacement for bigger displacement'  8-)
Alas, no more Omegas....
