Author Topic: steering wheel  (Read 1563 times)
claude76
  • prestwick
steering wheel
« on: 17 September 2007, 09:10:50 »
hi was driving along yesterday and turning corners and heard a clicking noise comming from the steering wheel as i turned sometimes it would kind of stick and you had to turn it a bit harder any ideas of problem cheers.
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
Re: steering wheel
« Reply #1 on: 17 September 2007, 09:23:23 »
Have you checked power steering fluid level?
[size=24]        [/size][/b]
davlad22
  • Sunny Yorkshire
Re: steering wheel
« Reply #2 on: 17 September 2007, 16:30:49 »
Clock spring?
HI2DVY
  • Deepest Darkest, Scotland
Re: steering wheel
« Reply #3 on: 17 September 2007, 21:45:19 »
Self cancelling indicator mechanism?
some day.....
Re: steering wheel
« Reply #4 on: 17 September 2007, 21:49:40 »
Any airbag light?, steering wheel controls and horn still working ok?
If you pop the indicator stalk out does it still do it?
bennyhive
  • London
Re: steering wheel
« Reply #5 on: 26 September 2007, 14:29:44 »
I had a similar experience. It turned out to be the airbag connector ring. This is a complex bakelite assembly and if bits break off it can cause the steering wheel to jam slightly similar to your experience. A local garage replaced mine at resonable charge. I understand VX have lots of spare connector rings in stock, so it must be a regular problem.
