Author Topic: Cruise control help.  (Read 1869 times)
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« on: 24 September 2007, 20:28:39 »
In the brief amount of time I drove my Omega today  ;D I could not for the life of me get the cruise control to work no matter what I pressed...
The display is reading Brake Light Check, yet all the bulbs work... Would this little woosie cause the cruise to not function at all??  Or is there a fuse/relay for it?
And just so I'm not completely stupid, could you tell me the correct way to actually use it??
Cheers
Humbugs...
Re: Cruise control help.
« Reply #1 on: 24 September 2007, 20:44:43 »
Yes, that may stop it working...
« Reply #2 on: 24 September 2007, 20:46:28 »
If you register at the vauxhall site you can download, in PDF format, the owners manual for your vehicle.. this will give you all sorts of usefull information on what various switches do ...  :)
« Reply #3 on: 24 September 2007, 20:58:05 »
I think you'll struggle to get prefacelift manual
jonathanh
  • coventry
« Reply #4 on: 24 September 2007, 20:59:40 »
Cheers
as The Boy says the Brake Light Check can spook the cruise unit.  first of all get to the bottom of that problem (some people have experienced this with ill fitting bulbs)
Second: how to use it.  Above 20mph, press the button with the 'pimple' on it.  Cruise will engage.  Button with dimple = reduce speed or resume.  Bottom button on stalk, marked O  is disengage
Good luck
« Reply #5 on: 24 September 2007, 21:43:17 »
Are the break lights working?
Sounds like the brake light switch is not functioning right.
davlad22
  • Sunny Yorkshire
« Reply #6 on: 25 September 2007, 00:24:53 »
Could be, could also be the obvious brake light bulb. Number of times I have experienced, or people moan about a 'dicky' bulb, they don't really fail from the heat or getting old, it's slamming the boot all the time that damages the filament.
...bit of useless information for you there  :y
PaulW
« Reply #7 on: 25 September 2007, 17:31:20 »
Hi all
Yeah the brake lights work fine, I've checked the bulbs too and they are all quite a tight fit, nothing loose, but then again they may be the wrong rating for what they are, etc... I'll get some new bulbs from Vauxhall to replace all the lights in the rear and then try it.
Also, whats the best way of testing the pedal switch??  Can it be done using a multimeter at all??  Just if the bulb replacements don't change a thing, I can give that a try aswell :)
Cheers
Humbugs...
PaulW
« Reply #8 on: 26 September 2007, 17:28:04 »
Right went to VX today, got a full set of rear bulbs and replaced the lot.  None are loose, there all working... BUT...
Brake Light Check...  :(
Got another lot tried again, same again...
Any ideas??
Humbugs...
« Reply #9 on: 26 September 2007, 18:58:27 »
check brake switch fully working (2 independent sets of contacts)
PaulW
« Reply #10 on: 26 September 2007, 19:01:49 »
I'm just going to replace it I think...  Given the car has done 160k, its probably easier than faffin about testing it...
You wouldn't happen to have the magic price for one from the red book would you??  :y
Humbugs...
« Reply #11 on: 26 September 2007, 19:05:40 »
not tc, but around £12 + vat from memory.  Anyone near you with decent code reader that can do live data might be useful ;)
switch can be tested with meter - it will get pricey swapping things without testing....
