Author Topic: Fitting Cruise  (Read 2212 times)
carper
  • Yorkshire - Hecky
Fitting Cruise
« on: 27 September 2007, 13:40:18 »
I've been reading up in the Guides about Fitting Cruise (Facelift Only). Came across indicator stalk on the bay... buy it now £20.99 + £1.89 pp.
I do'nt disbelieve this in the guide...
Go to vauxhall dealer and talk very nicely to mechanic. Cruise enabled with Tech2 in five minutes. Donate to mechanic's favourite charity.
Although this statement in the sellers description wont deter wether I buy one or not, just wondered thats all ???
( [quote from seller )...If you have the fly-by-wire then you should only need 2 switches for under the pedals and then the ECU resetting (take battery off for approx 30 minutes) and you have cruise control..
Is the sellers above quote true ???
Indicator Stalk........
 http://cgi.ebay.co.uk/Vauxhall-CRUISE-CONTROL-Stalk-Vectra-Omega-Indicator-CD_W0QQitemZ220154069428QQihZ012QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Re: Fitting Cruise
« Reply #1 on: 27 September 2007, 13:54:17 »
I think the seller is talking rubbish. On drive by wire cars there is an explicit setting in the engine ECU to enable cruise. This will not be reset by removing the battery! It requires a Tech 2 to program it. Also, certainly on my DBW (auto) car there was nothing to do in the pedal switch department. It was a case of add the stalk, Tech2 to enable it and I had cruise.
On a non-dbw engine you need to add the actuator which moves the throttle, the brake and, if manual, clutch switches and the stalk but there is no setting in the ECU to change since the cruise system is stand-alone.
Edited to say: Note that only the 2.2,2.6 and 3.2 Facelift cars are DBW. The 2.0, 2.5 and 3.0 are the not.
« Last Edit: 27 September 2007, 13:55:36 by Kevin_Wood »
davlad22
  • Sunny Yorkshire
Re: Fitting Cruise
« Reply #2 on: 27 September 2007, 13:58:54 »
That's a bit pricey for a second hand stalk, make them an offer or buy a new one. Is your car manual or auto? Auto shouldn't require any addtional parts, manual may require clutch & brake switch (being a GLS) but may also be present already. If required they are around £12 ea. i think? You can check by getting your head up under the dashboard above the pedals.
Vauxhall agents are funny people, some won't bat an eyelid but some get shirty if you tell them you've fitted it yourself and won't enable it. It requires a 'tech 2' computer system to enable. If they charge you full tech 2 analysis rate you're looking at £30 - 50. There are members/mods on here who have the equipment to do it and charge excellent rates. Otherwise, a vauxhall specialist.
Superb mod also  :y
davlad22
  • Sunny Yorkshire
Re: Fitting Cruise
« Reply #3 on: 27 September 2007, 14:00:39 »
Oops, on a 2.0 looks like you need the full kit with cable/actuator etc.
Re: Fitting Cruise
« Reply #4 on: 27 September 2007, 14:13:35 »
Correct.
It does not matter if its facelift or not its the engine....
2.0/2.5/3.0 - Needs all the trimmings, cables, control unit, acutator, switchs and so on but no tech2 needed.
2.2/2.6/3.2 - Just needs the stalk, and tech2. Some manuals need a clutch switch.
carper
  • Yorkshire - Hecky
Re: Fitting Cruise
« Reply #5 on: 27 September 2007, 14:22:26 »
Quote from: davlad22
I've got 2.0L Auto GLS (facelift),  2000 on an X plate.
Re: Fitting Cruise
« Reply #6 on: 27 September 2007, 14:26:58 »
carper -  your car will not need a tech2 enable for cruise. you just need all the bits and it will work.
davlad22
  • Sunny Yorkshire
Re: Fitting Cruise
« Reply #7 on: 27 September 2007, 14:28:45 »
As tunnie said, will work a treat but requires the full 'kit'. Bonus is, once fitted, it will work straight 'out of the box', so no computers/mechanics required  :y If you're feeling brave, go take it all off a vehicle at the breakers yard, otherwise, alot of people sell the appropriate equipment on 'the bay'. Good luck.
carper
  • Yorkshire - Hecky
Re: Fitting Cruise
« Reply #8 on: 27 September 2007, 14:36:37 »
Cheers guy's  :y it'll give me something to think about over the weekend.
Re: Fitting Cruise
« Reply #9 on: 27 September 2007, 19:50:20 »
Yup, on a 2.0 auto, you will need:
Actuator/Ecu
Actuator cable (quite rare for 2.0l 2nd hand)
Brake switch
4 wire stalk (£30 new from dealer - 2nd hand ones do not last)
hotel21
  • The Kingdom of Fife
Re: Fitting Cruise
« Reply #10 on: 27 September 2007, 20:35:20 »
Actuator/Ecu
Brake switch
..... and a clutch pedal switch if manual???    :y
Re: Fitting Cruise
« Reply #11 on: 27 September 2007, 20:58:17 »
Actuator/Ecu
Brake switch
Its pot luck on this one. Some have it some don't.
