Author Topic: Fault codes for the 2.5 td  (Read 1195 times)
CF
« on: 28 September 2007, 21:42:19 »
Hi. Does anyone happen to have a wiring diagram for the engine management system for the early 2.5 td? Similarly, I could use some information on the fault codes and, resistance values of the various sensors. Can someone point me in the direction of a publication with this information in?
I have a  2.5 td where the engine is taking excessive time to pick up when the accelerator pedal is depressed under load.
Thanks CF
Re: Fault codes for the 2.5 td
« Reply #1 on: 28 September 2007, 21:55:22 »
Thanks CF
Haynes manual has the wiring diagrams which cover the U25TD (and later X25TD) engine.  The rest of the manual doesn't cover the engine though :(
