Author Topic: self levelling suspension  (Read 2879 times)
sassanach
  • trowbridge
« on: 23 September 2007, 16:58:40 »
how does it work? i went to gatwick today and halfway there im thinking to myself, the ride is a bit choppy so i pull up on the hard shoulder(4am) and lo and behold the a*s of the car is about 2" higher than it used to be(maximum height).the level actuator is still attached to the suspension so where do i start?
davlad22
  • Sunny Yorkshire
Re: self levelling suspension
« Reply #1 on: 23 September 2007, 17:38:27 »
Damn, there was another thread like this not so long ago. Can't remember what the conclusion was. Obviously something has failed. I think there maybe a fuse to the levelling compressor but hopefully there's someone else able to help out  :-?
« Reply #2 on: 23 September 2007, 17:39:33 »
Suspension sensor feeds back to ecu, if ecu thinks its low, it fires up the pump...  ...quite a simple system...
sassanach
  • trowbridge
« Reply #3 on: 24 September 2007, 08:36:57 »
how does it release the air if it thinks its too high? ie after taking a heavy weight out of the boot.
« Reply #4 on: 24 September 2007, 08:46:24 »
There is a sensor on the rear drivers side trailing arm that monitors the rear ride height (close to the diff).
If to low, it trigges a relay which fires up the compressor and pumps the shock up. There is also a small valve which can be triggeres to lower it.
On my estate, just before it was written off. I was in the process of fitting a seat height adjustment switch in the boot so I could raise and lower the back manualy (coz the sensor was playing up!)
sassanach
  • trowbridge
« Reply #5 on: 24 September 2007, 08:59:13 »
whereabouts is the lowering valve located?
« Reply #6 on: 24 September 2007, 09:06:56 »
From memory, its on the pump under the drivers side front wing.
« Reply #7 on: 24 September 2007, 09:24:07 »
Yes it's around there somewhere as the vent pipe for it is just above the driver's head light.
meaney
  • newry. Northern Ireland
« Reply #8 on: 28 September 2007, 23:18:26 »
hi, i had the same problem recently, switch the car off and pull off the air pipe on the rear shock and the system will expell all the air, refit the pipe and clip and start the car up and it should refill the system and automatically adjust the level.
Wayne
« Reply #9 on: 29 September 2007, 00:00:07 »
does my 1998 S reg CDX Estate have this self leveling thingy?  lol
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #10 on: 29 September 2007, 01:24:43 »
Only the Elite had self leveling suspension as far as i am aware.
Jaguar XJ6
« Reply #11 on: 29 September 2007, 07:58:00 »
It was an option on all but the Elites.....check for the pipes connecting to the rear shocks.
