Author Topic: Possible Oil Cooler?  (Read 1277 times)
omegalord
« on: 29 September 2007, 17:01:58 »
Symptoms....
Steam coming from rear of engine when engine hot
Rubbery smell sometimes
Header tank is really really stained orangey colour
Ticks over roughly
Seems to use water
When i changed the rocker gaskets i noticed mayo in the oil filler neck
If not then what do you think it could be?
Matt   :(
Re: Possible Oil Cooler?
« Reply #1 on: 29 September 2007, 17:10:11 »
Symptoms....
Ticks over roughly
Seems to use water
Matt   :(
Don't think its oil cooler.  HBV maybe?
markey mark
  • SLady bitshorpe north lincs
« Reply #2 on: 29 September 2007, 18:04:17 »
not oil cooler matey ! :y try flushing coolant system new hbv check hoses at rear of engine !! :y
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« Reply #3 on: 29 September 2007, 18:30:19 »
Probably worth giving the breathers a clean through & if you haven't done already, a quick oil change  :y
Humbugs...
omegalord
« Reply #4 on: 29 September 2007, 18:31:56 »
Hi,  cleaned the breathers out and to be honest there was hardly any muck in at all. Havent changed the oil yet , was going to but just havent had chance yet.
Matt
