Author Topic: leak  (Read 1870 times)
raximax
  • dundee
leak
« on: 29 September 2007, 08:56:10 »
        is this a water pipe as i am loosing water and i think it is comming from here?????
« Last Edit: 29 September 2007, 10:21:29 by TheBoy »
mmeeggaa
Re: leak
« Reply #1 on: 29 September 2007, 10:23:00 »
yes, the rubber pipe from hbv goes to 'coolant bridge' - the metal rail you've highlighted.
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: leak
« Reply #2 on: 29 September 2007, 10:31:59 »
if its coming from coolant bridge, it may be worth renewing them pesky bolts and washers as a cheap hopeful fix, as well as ensuring the connecting rubber hoses are tight, full on and jubileed tightly.
raximax
  • dundee
Re: leak
« Reply #3 on: 29 September 2007, 12:20:05 »
thanks ill give it a go ;) :-/
mmeeggaa
Markjay
  • London
Re: leak
« Reply #4 on: 29 September 2007, 22:40:19 »
Are you sure it is not coming from the HBV and dripping onto the coolant bridge?
If it is the coolant bridge, are you sure it is not from the temp sender?
Failing that, then as said above....
Alas, no more Omegas....
raximax
  • dundee
Re: leak
« Reply #5 on: 29 September 2007, 22:53:58 »
now im lost  :-[ i took of the plenum got scared and put it on again car is now very lumpy it is drawing air. plenum gasket i think so i will have to wait till monday oh bother.....
mmeeggaa
