Author Topic: TYRES & CAMBER  (Read 2253 times)
MikeDundee
  • Costa Del Peckham
TYRES & CAMBER
« on: 29 September 2007, 08:08:39 »
Had to change the passenger side front tyre this week, thought it was just a ouncture; However it appears that it was the same problem I had with the drivers side front tyre some weeks ago when chopped it into kwik fits and had to put a new tyre on;
On the inside edge it has worn more on say 12'' section of the inside edge and not all the way around the inside edge; It has been suggested that this may be the Camber?
Heres some pics
« Last Edit: 29 September 2007, 08:35:51 by mickdundee »
Dazzler
  • Haverhill, Suffolk
Re: TYRES & CAMBER
« Reply #1 on: 29 September 2007, 08:23:05 »
Could be.....A new tyre and a trip to Wheelsinmotion me thinks....
MikeDundee
  • Costa Del Peckham
Re: TYRES & CAMBER
« Reply #2 on: 29 September 2007, 08:37:50 »
My mate reckons his mates tyre place in Brockley down the roa had a geometry set up, it was him that suggested it may be the camber?, be a trip to him first.
Re: TYRES & CAMBER
« Reply #3 on: 29 September 2007, 09:20:53 »
It is the camber but, you wont get better than Tony at Wheels in Motion, realy knows his stuff and has done enough Omegas to know what is right on them.
Re: TYRES & CAMBER
« Reply #4 on: 29 September 2007, 10:26:27 »
if its just one section, not entire circumference, wonder if wheel buckled a bit (along with camber issues)
I personally recommend Wheels-inmotion...
Danny
  • Wigan, Greater Manchester
Re: TYRES & CAMBER
« Reply #5 on: 29 September 2007, 12:00:20 »
I thought that, being as it would normally wear thin evenly right the way round... like mine did!
how much does it cost for camber adjustment?
bearing in mind I live about 300 miles away from said wheelsinmotion!
« Last Edit: 29 September 2007, 12:02:09 by D4NNY »
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Re: TYRES & CAMBER
« Reply #6 on: 29 September 2007, 13:21:33 »
I used a place called Drury Lane in Oldham (came recommended by WIM as a local place)
£45 for diagnosis and then whatever to adjust.
Cost me £86 last time I had it done.
Humbugs...
CF
Re: TYRES & CAMBER
« Reply #7 on: 29 September 2007, 16:26:12 »
Some camber can be adjusted using the bolts at the bottom of the strut that hold the stub axle and disc. Slacken both bolts and pull the top of the disc toward you. It is only a small amount of adjustment but will save you some tyre wear.
MikeDundee
  • Costa Del Peckham
Re: TYRES & CAMBER
« Reply #8 on: 29 September 2007, 16:31:43 »
If that is the case then both fronts would be buckled as had the same problem a few weeks back on the other side. the rims will be getting changed next week in any case over to the new irmschers :y, whereabouts is wheels in motion, I know hes moved from Watford?
Re: TYRES & CAMBER
« Reply #9 on: 29 September 2007, 16:34:05 »
Now in Hemel Hempstead, about 7m from Watford...
Dazzler
Re: TYRES & CAMBER
« Reply #10 on: 29 September 2007, 23:05:17 »
Is that miles or minutes :-/
Re: TYRES & CAMBER
« Reply #11 on: 29 September 2007, 23:06:12 »
both ;)
Dazzler
Re: TYRES & CAMBER
« Reply #12 on: 29 September 2007, 23:07:28 »
At 60mph i suppose it would ;D
