Author Topic: Car running cold  (Read 1498 times)
not technical
  • langold worksop, notts
  • having twin's great
Car running cold
« on: 30 September 2007, 09:20:24 »
Hello again, i recentley cleaned my iacv now my car temp doesnt go upto 90oc like itused to it barley gets off the botttom of the gauge have i done ewt wrong?
not good at mecanics but il have a go. need ewt knowing about a fridge or air con im ur man
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Car running cold
« Reply #1 on: 30 September 2007, 09:55:27 »
was it like this previously? How long have you run it?
Do you hear the fans kicking in? Sounds likea thermo issues, maybe.
not technical
« Reply #2 on: 30 September 2007, 11:31:04 »
took it on a run about 150miles today it was fine before i cleanned the iacv would a air lock do it
hotel21
  • The Kingdom of Fife
« Reply #3 on: 30 September 2007, 11:55:25 »
An air lock in the coolant system would give an effect on the sensor.  Its designed to read water temp, not air temp.
To ensure all air is out, from cold, put interior heater on hot, expansion cap off, top up water to level, start engine and regularly squeeze the large coolant pipe at the battery to burp air back into the header tank.  Keep running/burping until car at norm op temp then replace cap and take for a run.  Allow to cool (overnight preferred) then check/top up water level in the morning.
Should be OK then.
