Author Topic: Omega 2.5 td elite m reg acceleration problems!!  (Read 2475 times)
CF
« on: 26 September 2007, 20:49:24 »
I would welcome some advice with a problem on my rather old 2.5td auto. It is failing to accelerate when I put my foot down. It is rather flat when pulling off and has little throttle response until 5 seconds later when masses of power comes in. There are no warning lights showing.
Firstly, I would like to know of a fault code reader and manual that I could buy that would help check the data stored in the ECU. Secondly has anyone any ideas concerning this problem and its rectification.
Many thanks CF
Dazzler
  • Haverhill, Suffolk
Re: Omega 2.5 td elite m reg acceleration problems
« Reply #1 on: 26 September 2007, 20:52:40 »
When did it last have all its filters changed????? especially the diesel and air filter.
« Reply #2 on: 26 September 2007, 21:25:09 »
Check the hose from turbo to intake hasn't gone soft....
Need a good code reader - cheapo tech2 doesn't read it iirc
IrmscherKris
  • Manchester
  • banned due to bad trader references
« Reply #3 on: 27 September 2007, 00:21:47 »
Is it an auto? If so, check the gearbox oil...
CF
« Reply #4 on: 28 September 2007, 21:44:24 »
Thanks but all filters renewed as per service schedule - less then 1k miles ago.
CF
« Reply #5 on: 28 September 2007, 21:48:13 »
Thanks - Have checked the oil - that's OK. No change to the problem so its an engine fault problem.
Dazzler
« Reply #6 on: 28 September 2007, 22:35:26 »
How much fuel have you got in the tank?????
CF
« Reply #7 on: 29 September 2007, 07:43:11 »
Fuel just over half full!
« Reply #8 on: 29 September 2007, 10:19:46 »
may be worth bleeding it, but I'd expect it to idle erratic if air in there....
Omegatoy
  • UK
« Reply #9 on: 30 September 2007, 20:14:07 »
not quite sure of the problem here, if you have masses of power after 5 seconds or so then would guess the turbo has kicked in, below about 1800 rpm they are slightly flat, although not to bad should be a gradual urge building with an auto, from your description it sounds lke it all of a suden shoots off?  more info please?
CF
« Reply #10 on: 01 October 2007, 19:15:42 »
Hi
After hours of looking at wiring diagrams and testing bits The problem was found to be the air temperature sensor in the plenum chamber. It was caked in oil and grease and so unable to function properly. No warning lights or fault codes showed because the problem was not the failure of the sensor.
Cleaning inside the plenum chamber is a real task should anyone feel tempted - it fouls the bulkhead and so is an impossible task without removing the rearmost four studs. I now understand why this particular task has never been completed previously.
« Reply #11 on: 01 October 2007, 21:53:24 »
Hi
There is a knack to getting these off.  I can do it very quickly, due to excessive practice  ::)
