Author Topic: Ex plod 3.2 MV6 Auto cuts out  (Read 3637 times)
Mick_600
  • Warrington, Cheshire
« on: 30 August 2007, 21:03:23 »
Dear all. Had a strange problem today. Driving along and she just stops running (auto box so sudden lack of power steering makes life interesting ).
Engine turns over fine, plenty of battery power. I Left it around 10 minutes starts up and runs perfectly ....... several miles later, stops again with no warning.
When running the engine is perfect. When it stops, ignition light and oil light come on and no others. No engine management light warning so things like throttle body and crank sensor seem unlikely. Haven't been able to check for fault codes as my reader is at my mums .... typical ... but wouldn't have expected any with the em light not coming on.
I have just had a cam belt and rollers changed by a local specialist (£160   ) but having watched them do it they know their stuff, should do they used to build V6's at the factory and also the engine runs a lot better than it did before the change due to valve timing now being correct on both sides rather than just the one side which was the position before they did the work !! Still it was only like that for 40,000 miles lol. Seriously though bits they disconnected such as throttle body would cause the engine light to show and it doesn't and all leads are still correctly fitted and secure.
Any help would be very much appreciated and also if any of you are in the North West (they are near Chester) and need work doing at a good price by guys that know what they are doing rather than kids learning what to do, contact me and I'll forward your details somehow.
Thanks
Mike
ps sorry for tending to ask questions rather than help others but I am not yet sufficiently knowledgeable about these yet to be sure my advice wouldn't make things worse.
Nickbat
Re: Ex plod 3.2 MV6 Auto cuts out
« Reply #1 on: 30 August 2007, 21:09:54 »
When a crank sensor starts to fail, it doesn't always make the EML light show. I would say that is the most likely cause. Certainly not an expensive part and an easy DIY job.
Nick
« Reply #2 on: 30 August 2007, 21:10:09 »
crank sensor ::)
Paul M
  • Edinburgh
« Reply #3 on: 30 August 2007, 21:12:34 »
Sounds like the crank sensor is on the way out. Very common fault, and it causes the spontaneous cutting out then mysteriously starting and running perfectly again some time later. Not that difficult to change, although the part costs about £80 IIRC.
It doesn't bring on the EML light because there's no fault when the engine is running, and when it fails the engine stops and the EML comes on anyway.
Paul M
  • Edinburgh
« Reply #4 on: 30 August 2007, 21:13:40 »
 ;D
3 identical responses within 3 minutes.... think that's some consensus ;)
Oh and I need to type faster :D
« Reply #5 on: 30 August 2007, 21:13:41 »
identical symptoms to when mine failed.  Only mine decided to do it just outside Dijon, France.  Only my phrase book didn't cover "please can you send someone to tow my car off motorway", but I knew enough to tell mechanic he was talking BS that both my cats had failed!
« Reply #6 on: 30 August 2007, 21:14:54 »
Mine failed recently (3.2 auto). No engine light although there was a fault code stored.
I'd get the fault codes read, or just change the crank sensor.
Nickbat
« Reply #7 on: 30 August 2007, 21:18:42 »
Around the £34 mark from here:
http://www.crankshaftsensors.co.uk/Products.aspx?Man=VAUXHALL%20OPEL&Mod=OMEGA%20B&Ser=OMEGA%20B%203.2%20V6%20Saloon&Year=02/01%20%3E%2007/03&BHP=160&HP=218&CC=3175&Cylinders=06&Valves=24&VID=15808&typep=crankshaftsensors
Could probably source an even cheaper one from Ebay.  :y
« Reply #8 on: 30 August 2007, 21:27:35 »
Mine was only IRO 42 quid from main dealer on TC.
Paul M
  • Edinburgh
« Reply #9 on: 30 August 2007, 21:36:36 »
Bugger.. they've got a fair bit cheaper since I bought mine, that was from a retailer on fleabay 8-)
Mick_600
« Reply #10 on: 30 August 2007, 22:16:52 »
Thanks a lot guys .... That'll be a new Crank Sensor then.
Seen one on Fleabay for £38.50 inc VAT and p&p. Written to ask em if it'll arrive on Saturday.
Looks like I'll be forced to fix the wiper cover while I'm at it which is in about 6 bits due to the ripping out of the plod fittings when it was decommisioned.
Cheers again and with a bit more experience pulling it to bits I'll be able to add to forum rather than just take out. I'll post again when it is done and fixed.
Mike
Nickbat
« Reply #11 on: 30 August 2007, 22:28:48 »
Mike
Good luck mate! Remember to look up crankshaft sensor change in the maintenance section. Key thing is to make sure the new cable doesn't touch hot surfaces. Secondly, it's hard practically impossible to route it the way it was when the car was manufactured.
On the whole, though, an easy job. ;)
BTW, some details in your profile (type of car - yes I know it's 3.2!! - location etc.) would be useful. :y
Martin_1962
« Reply #12 on: 31 August 2007, 09:57:46 »
DEFINATELY Crank Sensor
« Reply #13 on: 31 August 2007, 10:21:35 »
Good luck :)
Shame you're so far away - i have a spare (slightly cracked) scuttle in the garage....
davlad22
  • Sunny Yorkshire
« Reply #14 on: 01 September 2007, 05:22:32 »
Is the old/new shape scuttle the same design??? I'm still trying to think what would have been attached to it to involve damaging it!?!
Mike, have you found many things that have been hacked up (headlights/wiring etc?) and does it run straight & true???
(sorry for off-topic  ::) )
All the best  :y
