Author Topic: Non revving 2.5td  (Read 4470 times)
maceanruig
  • Near Kirriemuir, Angus,
Non revving 2.5td
« on: 29 September 2007, 16:34:43 »
Hi,
I've diesel magiced it, as per the boy, I've checked the fuel filter for water - none. I've had it diagnosed - nothing showing. Looking under the bonnet I notice an electrical connection to the battery, blue that runs to a 15 amp fuse near a box with ZF on it. I'll replacethat soon as I get a connector. Also looking in the fuse box thingy under the bonnet I notice that no 1 relay is missing - maybe its supposed to be. Does anyone know what its for? A stupid question - of course somebody knows. It goes into a purplish connection. The car is a 96 2.5 td elite estate.
Thanks, john
Re: Non revving 2.5td
« Reply #1 on: 29 September 2007, 16:43:11 »
Hi,
Thanks, john
As for missing relay, see relay box layout posts in Tecnical Information section.
Is the pipe from the bottom of the inlet to the boost pressure switch OK?
maceanruig
« Reply #2 on: 29 September 2007, 16:49:02 »
Hi,
Thanks, john
Yes i think the guy who did the diagnosis fouind a propblem with this but sorted it and made no difference.
maceanruig
« Reply #3 on: 29 September 2007, 16:53:51 »
Hi,
Thanks, john
According to Mrk DTM Calib its a test connector.
« Reply #4 on: 29 September 2007, 16:58:52 »
Hi,
Thanks, john
Nothing plugs in to that then
« Reply #5 on: 29 September 2007, 16:59:29 »
Is it smoking a lot either at idle, or when booting it?
« Reply #6 on: 29 September 2007, 17:08:33 »
Check the inlet track from the airfilter, to the turbo, through to the intercooler and into the inlet....make sure that none of the pipes have come off.
maceanruig
« Reply #7 on: 29 September 2007, 18:09:11 »
No
« Reply #8 on: 29 September 2007, 19:39:19 »
Hmmm, out of ideas at the moment.  Hopefully one of the diesel experts can suggest something...
CF
« Reply #9 on: 30 September 2007, 10:32:09 »
Hi
What year is the car? I seem to have the same problem with my 2.5td at the moment but my car is a 95 vintage. Mine does not appear to be maturing gracefully!!!
Try looking under the pellum ( not sure of spelling) chamber - the large aluminium air intake that sits on the RHS of the engine. Between the underside of the second and third air intakes there is a sensor - unclip the electrical socket and try the engine again to see if that makes a difference. Leave the sensor in the casting. I believe it is an air intake temperature sensor. Let me know if there is any change - it certainly made a difference to mine!!!
maceanruig
« Reply #10 on: 30 September 2007, 11:26:55 »
Hi
Hi CF Mine is a 96 so I'll have a look. I think the word you're looking for is plenum which broadly is a space to allow air circulation. I'll let you know.
« Reply #11 on: 30 September 2007, 18:01:25 »
So you have checked all the inlet piping then?
Omegatoy
  • UK
« Reply #12 on: 30 September 2007, 20:07:38 »
well apart from the title anyone know what it is or isnt doing? does it tickover but not rev when pedal pressed? does it not pull under load? have i missed somthing, or what???
Onegatoy
maceanruig
« Reply #13 on: 01 October 2007, 12:59:01 »
Onegatoy
Hi, sorry I had an earlier post - it revs up to about 3,500 -3,700 when not under load and to about 3,000 - 3,100 when driving gets up to that no bother but won't go any higher - a pain in the arse as the auto box keeps dropping to a lower gear. A previous owner reckoned it may have the wrong fuel pump. I've had it diagnosed and he could find no fault.
maceanruig
« Reply #14 on: 01 October 2007, 13:00:45 »
There's no many bits of plumbing! Wouldn't the diagnostic chap have noticed loose or missing pipes - or am I just being naive?
