Author Topic: Non revving 2.5td  (Read 4450 times)
CF
Re: Non revving 2.5td
« Reply #15 on: 01 October 2007, 19:01:10 »
Hi
After reading your posted message of today I think your problem might be different to mine experience. On my vehicle it would, under load, rev to about 2k then hesitate for rather a long time before steadily starting to rev again. It would then rev to the maximum with some effort. As I said previously, the problem was the air temperatre sensor below the plenum chamber. It is located below the intakes of cyclinders 1and 2 not as I stated before. I cleaned the sensor, checked that there was some kind of resistance and replaced it - all now appears to work fine. While doing this I looked inside the plenum chamber - it was absolutely caked in thick grease. I cleaned out as much as possible - not an easy task to do well. Also the plenum chamber is not easy to remove fron the head as it fouls the bulkhead. I did contemplate removing the studs which hold it place but thought better of it. Needless to say the car is running again and sounding OK.
Omegatoy
  • UK
« Reply #16 on: 02 October 2007, 01:47:58 »
sounds like a maf sensor or boost sensor fault poss air temp fault but almost definetly a sensor
Omegatoy
