Author Topic: intermittent poor starter.  (Read 1969 times)
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« on: 01 October 2007, 18:19:20 »
2.5td '00. Sometimes it starts "right on the button" and other times it'll take about 4-5 seconds of cranking, and sometimes 2 or 3 attempts at that. Battery ok,  it spins the starter motor at heck of a rate. My mate sez it sounds like a machine gun when he's stood outside and it's doing it's in non-firing mode.
I've also had it die on me with symptoms of out of diesel with the "Range" showing 45 miles and once showing 75 miles. Managed to get it going and get to a fuel station as long as I kept the revs up.
I've changed the fuel filter and that did nothing. The slow in starting is usually when the motor is warm. Cold starting is pretty good.
Any ideas me dears ?
Dazzler
  • Haverhill, Suffolk
Re: intermittent poor starter.
« Reply #1 on: 01 October 2007, 18:26:02 »
When was it last serviced??? fuel filter,air oil etc......
There has been on here a fault where if the fuel drops below 1/4 tank then the engine losses power. This was put down to the fuel pump in the tank itself having become weak in its output.
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #2 on: 01 October 2007, 18:32:07 »
Sounds like the priming pump that is submerged in the fuel tank is at fault
IW
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #3 on: 01 October 2007, 18:33:17 »
Any engine management light? Have you paperclip tested it for fault codes?
« Last Edit: 01 October 2007, 18:33:39 by Markiec »
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #4 on: 02 October 2007, 10:37:56 »
Changed the air and fuel filters. Oil and filter change this weekend.
Markie
« Reply #5 on: 02 October 2007, 11:41:07 »
and have you paperclip tested it yet?
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #6 on: 02 October 2007, 12:13:01 »
No, not paperclipped it yet. I'll read the post on how that's done.
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #7 on: 02 October 2007, 12:43:31 »
Hmm...mine's a '00 2.5td.  Apparently things change after '99 and the codes cannot be flashed up.  Is this correct ?
Markie
« Reply #8 on: 02 October 2007, 13:05:06 »
is it pre or post facelift ?
Danny
  • Wigan, Greater Manchester
« Reply #9 on: 02 October 2007, 13:06:40 »
codes can be found with the paperclip test on some newer cars, works on my 2000 facelift
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #10 on: 02 October 2007, 13:14:54 »
Post Facelift. Last of the 2.5td's
