Author Topic: WIERD TEMP  (Read 2309 times)
trainmanone
  • stockport
WIERD TEMP
« on: 03 October 2007, 15:47:44 »
Hi gang, changed rad on 2l 16v auto due to old rad being cracked.
temp when fans kicked used to be around 95 deg now they kickin at about 89 deg.
rad seems cool to touch a bit concerned as not sure what temp fans should kickin at or is it overcooling
pete
what was that ??????
Re:  WIERD TEMP
« Reply #1 on: 03 October 2007, 16:04:02 »
As long as the fans don't run all the time I wouldn't worry, although it sounds cool. What temperature does it normally run at when moving?
Are you on the same fan switch in the new rad or did it come with a new switch?
trainmanone
  • stockport
Re:  WIERD TEMP
« Reply #2 on: 03 October 2007, 16:15:44 »
when running temp about 90 deg and same switches like i said before running about 95 deg before fans kickedin
pete
Re:  WIERD TEMP
« Reply #3 on: 03 October 2007, 18:05:49 »
So if it's running at 90 now and the fans cut in at 89 does that mean the fans run all the time?
It could be that there was some muck on the fan switch previously and this has been dislodged. I have seen this affect the temperature at which they switch before.
trainmanone
  • stockport
Re:  WIERD TEMP
« Reply #4 on: 03 October 2007, 18:14:41 »
just had thought could the fan switches be kaput if so how much for new ones ??
Re:  WIERD TEMP
« Reply #5 on: 03 October 2007, 18:39:08 »
Could well be the fan switch. I wouldn't have thought they'd be hugely expensive. Under a tenner would be my guess but who knows what the main dealer markup is?
The way to check is to give it a good run at "main road" speeds and let the temperature stabilise, then pull over and pop the bonnet. It should take a minute or two for the temperature to get high enough to start the fan, maybe more. You should also see the gauge move up significantly from the normal running temperature.
As a guide to what to expect (mine's a V6 so will be different) mine runs at 85-90 when on the move and the fan starts at probably 95, so there is a distinct increase before the fan runs. The gauges aren't wonderfully accurate so it's the relative temperature that's important, and that the fan isn't running at normal cruising temperatures.
trainmanone
  • stockport
Re:  WIERD TEMP
« Reply #6 on: 03 October 2007, 19:10:27 »
just been for a run temp shows 90 deg fan on all the time , me now thinks switch is bust.come to think of it poss due to crack in old rad and running very low on coolent could have tosted the switch`s
pete
Re:  WIERD TEMP
« Reply #7 on: 03 October 2007, 20:06:18 »
v6 ones about £20
trainmanone
  • stockport
Re:  WIERD TEMP
« Reply #8 on: 03 October 2007, 20:19:52 »
latest: just done a 20 mile motorway run temp didnt rise above 90 deg fans on all time me thinks defo switch , as there is two switches on passenger side of rad is it top or bottom switch i need .
pete
