Author Topic: Steam from Bulkhead!  (Read 3381 times)
Johnopaulo
« on: 03 October 2007, 20:30:08 »
Need some help please.
My omega 2.2 v6 auto decided only 2 days ago to throw steam from under the windscreen at the bulkhead somewhere. This happens only after short trips. Just prior to this happening I found puddles of water on the ground under the car. The car does not over heat at the temp gauge stays normal. The heaters are working, well the blow hot and cold air, so I ASSUME THATS NORMAL! I have an orange tint in water in the expantion tank. I dont see any bubbles coming through it though when the cap is off. CAn someone help please.
Thanks
Paul
hotel21
  • The Kingdom of Fife
Re: Steam from Bulkhead!
« Reply #1 on: 03 October 2007, 20:32:17 »
Fair chance its the heater bypass valve thats failed.
Check out the maintenance guides for a better description of fault and easiest means to repair.....   ;)
The Cambelt Kid
  • Derby
« Reply #2 on: 03 October 2007, 20:36:01 »
I had this on my V6 while doing some work on the HBV.  I needed to cut into the pipes for my LPG install and ended up splashing coolant down the back of the engine.  It turned out to be my shi**y connection which i soon rectified.  You may have a leak around that area.  Also i noticed i am finding it very very difficult to engage gears, 1st and 2sd are quite bad!  I hear that leaks near the HBV can cause this.
In fact, why am i bangin on about gears - you've got an auto!  :-X
Might be worth taking a peek at the rear of the plenum for any leaks.
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
The Cambelt Kid
  • Derby
« Reply #3 on: 03 October 2007, 20:37:14 »
OMG, i was correct but too ruddy late, H21 you beat me!
hotel21
« Reply #4 on: 03 October 2007, 20:39:52 »
Not claiming to be 100% spot on with diagnosis, just my fingers typed faster than yours!!   ;D
« Reply #5 on: 03 October 2007, 20:53:13 »
My omega 2.2 v6
Thanks
Paul
Errr  :-/
Need to confirm, the 2.2 is a straight4 not v6.
Johnopaulo
« Reply #6 on: 03 October 2007, 21:05:53 »
The car is an 2.2 injection v6 automatic.
Johnopaulo
« Reply #7 on: 03 October 2007, 21:10:11 »
I dont have a manual to hand so does anybody have any pics or diagrams that would help me locate and replace the HBV? This would be greatly appreciated. Another question: until I can fix this problem at the weekend is there any way of runing the car safely and avoiding the steam issue?
Regards
Paul
« Reply #8 on: 03 October 2007, 21:15:17 »
There never was a 2.2 V6 engine fitted to the Omega....
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #9 on: 03 October 2007, 21:24:33 »
HEATER BYPASS VALVE,KNACKERD, SEE THE MAINTENANCE GUIDE HOW TO FOR DETAILS. :y
Jaguar XJ6
« Reply #10 on: 03 October 2007, 21:29:46 »
Wrong engine fitted ?? Therefore pipes / connections not fitting properly ??
 ;D ;D ;D ;D ;D
Johnopaulo
« Reply #11 on: 03 October 2007, 21:38:58 »
sorry folks. Just bought the car and I really didnt take note of exactly the engine model, and it dark and raining outsider and I know says 2.5i on back not 2.2 and it is an automatic.
regards
Paul
omegalord
« Reply #12 on: 03 October 2007, 21:43:27 »
I'd say HBV then , is your water pressurising in the header tank?
Matt
« Reply #13 on: 03 October 2007, 21:45:51 »
I agree, check HBV first...
Johnopaulo
« Reply #14 on: 03 October 2007, 22:30:05 »
Yes , the water is pressurising in header tank
regards
Paul
