Author Topic: Steam from Bulkhead!  (Read 3378 times)
omegalord
Re: Steam from Bulkhead!
« Reply #15 on: 03 October 2007, 22:31:42 »
Hi,
Is the mid flashing up "coolant low"?
And are you losing water?
If so then its definitely HBV i would say.
Mine is doing exactly that and getting it replaced 2moro
Matt
« Reply #16 on: 03 October 2007, 22:34:23 »
The car is an 2.2 injection v6 automatic.
As mentioned there was never a 2.2 V6 fitted to the Omega, engines where for the later cars:
2.2 Petrol 4 cylinder
2.2 Diesel 4 cylinder
2.6 & 3.2 V6 Petrols...
I suspect it is the HBV but we need to make sure what engine you have as the locations are different.
omegalord
« Reply #17 on: 03 October 2007, 22:35:57 »
sorry folks. Just bought the car and I really didnt take note of exactly the engine model, and it dark and raining outsider and I know says 2.5i on back not 2.2 and it is an automatic.
regards
Paul
Johnopaulo
« Reply #18 on: 03 October 2007, 22:36:05 »
I have looked on the guides pages and can't seem to find the page that relates to checking and removing the HBV...
...and thanks so far to everyone who has helped. It is greatly appreciated.
Regards
Paul
omegalord
« Reply #19 on: 03 October 2007, 22:38:21 »
Its not an easy job but certainly not a very hard job if you know what i mean.
Involves taking scuttle panel off, wipers etc
Then reach round the back of engine , take 3 pipes off , throw old HBV , connect new HBV back to 3 pipes in correct order.
Voila!
ians
  • Reading
« Reply #20 on: 03 October 2007, 22:57:04 »
I don't think there is a maint guide on the HBV (would be good idea as its such a common failure).
There are those that will tell you that you can do it in 5 minutes, blindfold with one hand tied behind your back... ;D ;D
However, in my case, I removed wipers/scuttle,  and plenum (as I was doing breathers/camcover seals at the same time).   Access is much easier then and you can see what you're doing. There are a number of fragile vacuum connections round there that you don't want to break.   Job itself is straightforward and the part is c. £30 from Vx (don't use aftermarket)
