Author Topic: Car is sluggish  (Read 4666 times)
Martin_1962
Car is sluggish
« on: 03 October 2007, 09:46:07 »
Last few days my car has been feeling sluggish, got new plugs, air filter is clean, what else to check?
omegalord
Re: Car is sluggish
« Reply #1 on: 03 October 2007, 09:53:54 »
Multirams!
Martin_1962
Re: Car is sluggish
« Reply #2 on: 03 October 2007, 09:57:25 »
No error codes, but it does seem a little slow off the line.
I'm thinking could be breathers or throttle body, failing that running too cold.
omegalord
Re: Car is sluggish
« Reply #3 on: 03 October 2007, 11:20:21 »
Wouldnt always give a code if the rams werent working. Mine didnt work and had no light come on. It might just be worth checking.
Matt
Re: Car is sluggish
« Reply #4 on: 03 October 2007, 18:25:40 »
Any difference on petrol/LPG?
Check the multirams..
Re: Car is sluggish
« Reply #5 on: 03 October 2007, 18:32:20 »
Cat (feline) stuck in back box?
 ;D
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Re: Car is sluggish
« Reply #6 on: 03 October 2007, 18:42:31 »
 ;D
Just wait for it to explode, its what I did  ;D
Humbugs...
Re: Car is sluggish
« Reply #7 on: 03 October 2007, 18:42:40 »
What is the Mileage ..?
did you changed any of the sensors ?
also like stated any difference between  LPG/normal fuel
« Last Edit: 03 October 2007, 18:44:04 by cem_devecioglu »
Martin_1962
Re: Car is sluggish
« Reply #8 on: 03 October 2007, 19:08:25 »
Similar - very little difference.
The power drop feels like a very hot summers day.
DBW are a bugger to check - I'll have a look at dinner time - only the rear one moves without a load doesn't it
Martin_1962
Re: Car is sluggish
« Reply #9 on: 03 October 2007, 19:09:27 »
 ;D
No
Martin_1962
Re: Car is sluggish
« Reply #10 on: 03 October 2007, 19:11:36 »
97000
Crank about 3 months ago
Normally I get on acceleration around
7.8 petrol, 9.0 gas
now getting 9-9.5 on both.
It has had an Italian tune up
It is due an oil change (early not 10,000 miles)
Plugs are good, coil packs seem OK.
I will check the exhaust at the weekend
Re: Car is sluggish
« Reply #11 on: 03 October 2007, 20:05:05 »
The weight of that bloody great fart juice container in boot.
Seriously, check for vac at multirams.  Hope its not throttle body beginning to fail, crappy DBW things...
Re: Car is sluggish
« Reply #12 on: 03 October 2007, 20:44:37 »
97000
7.8 petrol, 9.0 gas
assuming a healthy car and blocked egr only can be lambda sensors becoming old or cats..(mine was)
ps : although not logical I see cars used in LPG for a long period have drop in fuel performance also even with seperate ECU.
Can be related to LPG subject.
« Last Edit: 03 October 2007, 20:49:24 by cem_devecioglu »
Martin_1962
Re: Car is sluggish
« Reply #13 on: 03 October 2007, 21:25:16 »
Well I'll check the exhaust this weekend, don't know if it is possible to remove cats, I may enquire.
Martin_1962
Re: Car is sluggish
« Reply #14 on: 04 October 2007, 14:42:46 »
Front ram - my piece of wire wobbles when floored, so it works.
Can't even see rear ram - except for a bit of pipe.
On overrun it sounds like a bit of fuel is getting through as it pops a little.
Sounds like a manifold is blowing when cold :(
Suspect exhaust leak too
