Author Topic: Brake bleeding sequence  (Read 2770 times)
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« on: 04 October 2007, 21:36:14 »
Can someone please confirm the sequence for brake bleeding? ::)
Trade club card holder
Code scanner available
Re: Brake bleeding sequence
« Reply #1 on: 04 October 2007, 21:39:39 »
There is nothing in the tech manuals to define this ... but I always work from furthest to nearest in relation to the master cylinder
hotel21
  • The Kingdom of Fife
« Reply #2 on: 04 October 2007, 21:44:58 »
What he says....  Reverse bleeding not recommended though as can flip seals in the ABS unit...
alexandjen
  • The Silver Surfer
« Reply #3 on: 04 October 2007, 21:56:32 »
Sorry for my ignorance........reverse bleeding?? ::)
« Reply #4 on: 04 October 2007, 22:17:34 »
Reverse bleeding is forcing the fluid in at the brakes and removing it from the master cylinder ... on some vehicles this is the only way to remove all airlocks ... as already stated .. don't do it on a miggy .. it won't do the ABS any good at all.
I (we) did mine on sunday .... SWMBO sits in the car and operates the pedal in time with the spoken command ...  IN ......   OUT ... :)   cheaper than buying an easibleed or similar !!  :)
« Reply #5 on: 04 October 2007, 22:42:53 »
post 98 are independent systems from ABS unit, so sequence unimportnat.  Personally, I go diagonal, starting drivers rear, passenger front, passenger rea, driver front.
And do NOT let air get in ABS unit - that will be a PITA.
« Reply #6 on: 04 October 2007, 23:06:40 »
Mr Haynes says:-
Pre 98 models with 3 channel ABS
Front left
Front right
Rear left
Rear right
Post 98 with 4 channel
Left rear
Right front
Right rear
Left front
alexandjen
  • The Silver Surfer
« Reply #7 on: 05 October 2007, 19:33:52 »
Thanks guys, Andy I didn't know that Haynes made a manual for 2001 model if they do where can I lay my hands on it?
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #8 on: 05 October 2007, 19:52:52 »
ALEX, POST 98 MODELS ARE NOT FACELIFT, THEY ARE MINI FACELIFT, AND MR HAYNES DOES NOT COVER MY2000 CARS.
Jaguar XJ6
« Reply #9 on: 05 October 2007, 22:20:52 »
Haynes manuals just go up to mini face lift ie 99
I would think a Haynes for even a post 2000 car would have its uses. It would just be a case of suck & see & use a bit of common dog.
