Author Topic: Aire leaks  (Read 1408 times)
Don9247
  • Mottingham
Aire leaks
« on: 05 October 2007, 21:41:28 »
Hi I would like to know the correct way for getting trapped air out of the water system as I had a bottom radiator hose go on me :( , i have tried letting all the water out with the valve refilling let car till its hot let it cool down and topped water up agin but for some reason the heater doesnt work anymore doesnt blow hot air just slight warm porbley warm air from ebgine, I am sure this is down to the cooling system having air as also after the car is hot i can hear boiling form arounf the plennum any help guys much apprieciated! :)
hotel21
  • The Kingdom of Fife
Re: Aire leaks
« Reply #1 on: 05 October 2007, 22:34:36 »
Howdoo Don.  Principle been covered many times and reasonably straightforward, actually.
From engine cold, put interior heater on hot.
Top up header tank, leave cap off.
Start engine and allow to warm gently, squeezing the large hose beside the battery frequently to 'burp' air out into the header tank.
Top up tank as required throughout.
Ensure interior is blowing hot air, may take a wee while.
Once temp guage is warm, replace cap and take for a drive.  Ensure temp guage is all normal and OK.
Leave car to cool overnight then check level in the morning and top up as required.
All should now be OK.
B
Don9247
  • Mottingham
Re: Aire leaks
« Reply #2 on: 06 October 2007, 19:16:33 »
sweet cheers man all sorted now. ;) ;D ;D
