Pages: 1 [2] 3  All   Go Down
Author Topic: V6 cam change time... HELP!!!!  (Read 6970 times)
The Cambelt Kid
  • Derby
Re: V6 cam change time... HELP!!!!
« Reply #15 on: 07 October 2007, 19:57:50 »
I'll take a peek later tonight when i return home.  The cam cover had no stickers on it, so i'm going to take it from the V5.
Cheers
Marc
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #16 on: 07 October 2007, 20:41:39 »
IT IS STAMPED OM THE ENGINE BLOCK NEXT TO THE OIL FILTER ON A FLAT SURFACE.
Jaguar XJ6
The Cambelt Kid
  • Derby
« Reply #17 on: 07 October 2007, 21:52:02 »
Kit is dependant on your engine number.
To 08300418 you need 93188674 £143 retail £128.70 trade £89.08 TC
08300419 to 08578511 its 9201887 £118.00 retail £106.20 trade £89.08 TC
08578512 onwards its 93172354 £121.00 retail £106.20 trade £89.08 TC
Mine is 0867**** so i'll be needing the latest (93172354)
Thanks for the info C-Zok!
maria
  • Derbyshire
  • I'm proud to be welsh :)
« Reply #18 on: 07 October 2007, 21:52:59 »
It's actually parallel with the gearbox bellhousing, on the engine block...
It's stamped in vertically..
The Cambelt Kid
  • Derby
« Reply #19 on: 07 October 2007, 21:55:16 »
Later cars don't have the lower adjuster.  Different procedure for fitting one of them (slightly).
By the notch is a number, indicating which cam that notch is for.
How does the install differ on a 2.6?  Anything major i need to be aware of?  as it stands on my dad's drive now it has all cams and crank locked and ready for belt kit.
Cheers
M
« Last Edit: 07 October 2007, 21:56:17 by Omega2000w »
« Reply #20 on: 07 October 2007, 21:59:57 »
Cheers
M
There is something about winding back to 10 degrees BTDC...  ...Kevin Wood has done one recently...
maria
  • Derbyshire
« Reply #21 on: 07 October 2007, 22:01:43 »
Cheers
M
On Bob dents cambelt, just fitted the kit as per normal, cranked by hand, and the 2-4-6 bank was timed up perfectly :)
Quick tweak on the 1-3-5 bank, and job done.
Makes it a lot easier :y
The Cambelt Kid
  • Derby
« Reply #22 on: 07 October 2007, 22:11:07 »
Cheers
M
Maria/TB...
I see that makes sense!  Quite a lot of sense!  So banks 3/4 can never be out from teh crank then, it's only 1/2 that needs the timing.
I take it this was a quick tweak by GM to save time and money.
Thanks guys and gals  :y
maria
  • Derbyshire
« Reply #23 on: 07 October 2007, 22:15:31 »
Cheers
M
Maria/TB...
Either that, or we just got lucky  ;D
Done a couple of these later ones now, never seems to cause a problem.
If there are no markings on the belt, leaving an extra tooth than you would normally between the crank and tensioner works well for me = stops the cams from being a tooth out after the first rotation.
But.. that's personal opinion only, not to be relied upon ;D
JasonH
« Reply #24 on: 07 October 2007, 22:17:25 »
On my 2.5 facelift you have to thread the belt a bit differently just to get it on. If I can remember I had to loosely put it round the crank 1 tooth out and fit it round the idlers working anti-clockwise as you look at the engine. The belt went round the tensioner last then you could correct the belt position on the crank.
maria
  • Derbyshire
« Reply #25 on: 07 October 2007, 22:19:14 »
Seems a bit complicated, but as I say, each to their own.
I start at the crank, then up to the tensioner, around the 1-3-5 bank, then around the top idler, over the 2-4-6 bank, and then I fit the lower idler...while holding the belt back..
A380 Elite
  • Ashford, Middx.
« Reply #26 on: 07 October 2007, 22:23:50 »
Me thinks, Maria will be teaching me how to.
See you very Soon.
Darth Loo-Knee, He The Man
maria
  • Derbyshire
« Reply #27 on: 07 October 2007, 22:25:51 »
See you very Soon.
Yes, on the 18th October ;) ;D
JasonH
« Reply #28 on: 07 October 2007, 22:33:02 »
Maria - good tip. I was working from the Vx college V6 manual......
The Cambelt Kid
  • Derby
« Reply #29 on: 07 October 2007, 22:45:28 »
Here is a couple of pics from earlier today.  I'm not too sure how the timing could be out like this on a 2.6, maybe the crank jumped a tooth?
(CAMS 1+2)
(CAMS 3+4)
The reason i stripped down to investigate was slight loss in power (felt like it was holding back) and MPG wasn't the best either.  I also noticed that the injector timings between banks were different too.  Hopefully a new and correctly installed kit will make things a whole lot better.
Also i noticed that the tentioner did not load/unload while manually cranking round with the old belt in place, i take it that this is wrong?  It seems to be springy while in the vice, but not while it was on the car...
« Last Edit: 07 October 2007, 23:06:46 by Omega2000w »
Pages: 1 [2] 3  All   Go Up
Page created in 0.024 seconds with 20 queries.
