Author Topic: Check light.  (Read 1427 times)
amigov6
Check light.
« on: 08 October 2007, 21:32:05 »
When lights are on there's a small light saying "check" just to the right of the clock & below the date on the central display. After the lights have been on for a few seconds it lights up. All the lights work, even the front foglight that was'nt working at the Lakes!!!
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
Re: Check light.
« Reply #1 on: 08 October 2007, 21:33:51 »
Does it go off when you press the brake pedal Guy?
Re: Check light.
« Reply #2 on: 08 October 2007, 21:34:20 »
Sure all 4 tail lights are working?
Chopsdad
  • Keep it clean!
Re: Check light.
« Reply #3 on: 08 October 2007, 21:35:20 »
If the bulbs aren't genuine Vx ones there can all light up but read as faulty at the dash.
amigov6
Re: Check light.
« Reply #4 on: 08 October 2007, 21:46:32 »
Just checked tail light & rear fogs. All ok.
Re: Check light.
« Reply #5 on: 08 October 2007, 21:47:08 »
There are 4 tail lights, 2 per side.
amigov6
Re: Check light.
« Reply #6 on: 08 October 2007, 21:56:50 »
Display comes up with brakelight check, goes off when brake pedal pressed. Then displays outside temp for a few seconds, then displays Head/Tail lamp which will stay on unlil i press the top button on the indicator stalk, then it goes back to outside temp & stays there, but little check light still on.
amigov6
Re: Check light.
« Reply #7 on: 08 October 2007, 22:18:00 »
Just found the offending black bulb, Cheers Jaimie, Mark & all.
Page created in 0.023 seconds with 20 queries.
