Author Topic: MV6 Problems  (Read 1421 times)
volcanezx
MV6 Problems
« on: 09 October 2007, 09:02:21 »
Just bought an ex police MV6 estate, everything was fine fans came on shortly after 90 and cooled it down till about 87 or so. On sunday I was out and noticed the fans didn't come on when parked but made sure not to boil the car.  I bought the car for diffing and drifting can anyone tell me where the thermostate is so i can remove it and also how i can wire the fans up via a switch or get the fans to come on earlier. I've only done 200 miles in the car when i bought it i made sure there was no big pressure in the water bottle and there wasn't now however it seems that there is pressure in it can ANYONE HELP?????
Re: MV6 Problems
« Reply #1 on: 09 October 2007, 09:13:51 »
Here is
http://i181.photobucket.com/albums/x80/mecdv6/thermostat.jpg
dont use external switch ..it brings other problems
Re: MV6 Problems
« Reply #2 on: 09 October 2007, 09:31:42 »
I wouldn't remove the termostat either. That won't help and it's a nightmare to get to.
Sounds like you might have a dodgy fan switch, blown fuse in the engine bay fuse box or possibly a dodgy fan relay.
The cooling system should pressurise due to the expansion of the water, so that's OK.
volcanezx
Re: MV6 Problems
« Reply #3 on: 09 October 2007, 10:31:27 »
thanks just seems like such bad luck after so few miles and the car being a 2000. is the swicth the brass connection on the rad??
Re: MV6 Problems
« Reply #4 on: 09 October 2007, 19:13:18 »
The fan temp switches are in the rad.
Page created in 0.035 seconds with 20 queries.
