Author Topic: Symptoms of a failing cam sensor? 2.2i petrol  (Read 5953 times)
omegadan2.2i
  • Worksop, Notts
« on: 07 October 2007, 20:51:53 »
Can anyone tell me what the classic early symptoms are of a failing cam sensor on a 2.2i petrol?
Thanx in advance!
Dan
Dazzler
  • Haverhill, Suffolk
Re: Symptoms of a failing cam sensor? 2.2i petrol
« Reply #1 on: 07 October 2007, 20:53:55 »
Bad starting when warm (engine that is ) and possible rev limiting to about 4500rpm
omegadan2.2i
  • Worksop, Notts
« Reply #2 on: 07 October 2007, 21:37:24 »
Hmm...okay.  I'll tell you my problem.  I have noticed recently that sometimes when accelerating quite quickly to 60 or 70mph, the car sometimes feels as though it is holding back slightly through the revs, and then the power comes back (like a 'surging' sensation).
I also had a strange experience when coming back from Skeg one night recently on the A158, driving at approx 55mph, the engine 'lost' all power for approx. 2 seconds, and then came back (with a slight jolt).  Expected EML to light but nothing.  Never happened since.....
Omega is a 2.2i CD Auto saloon with 35k on the clock.
Dan
Dazzler
« Reply #3 on: 07 October 2007, 21:41:56 »
Possible failing crankshaft sensor.......but as you know it really needs to be code read first before thrwing lots of money at guess work.
Any Auto electrican should be able to read the codes, or someone on here may have an aftermarket code reader that may do the trick.
maria
  • Derbyshire
  • I'm proud to be welsh :)
« Reply #4 on: 07 October 2007, 21:41:58 »
Before condemning anything - you need to read your fault codes...
omegadan2.2i
  • Worksop, Notts
« Reply #5 on: 07 October 2007, 21:48:36 »
I am planning to have a run down to Nottingham to see Marks DTM for an autobox upgrade in the near future, perhaps he could have a look with his TECH2.  I hear that he is a top bloke!! :y
Thanx
Dan
Dazzler
« Reply #6 on: 07 October 2007, 21:55:39 »
Thanx
Dan
That he is mate, that he is ;)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #7 on: 07 October 2007, 21:59:43 »
That's your best bet, get it Tech'd by Mark.
Camshaft sensor usually brings on the spanner light and/or EML light, after not starting first time when warm/hot.
I like red cars
The Cambelt Kid
  • Derby
« Reply #8 on: 07 October 2007, 22:01:27 »
Thanx
Dan
I'll second that too! :y
My camshaft sensor failed but if it wasn't for the EML i wouldn't have noticed!  I understand that the CSS generates a 'hall effect' which it read by the ECU.  Without this the ECU doesn't know what position the cams are in and in your case it might jump into limp mode...
CCS on a 2.0/2.2 isn't difficult, it can be done within the hour.
« Last Edit: 07 October 2007, 22:06:17 by Omega2000w »
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
Taxi_Driver
« Reply #9 on: 08 October 2007, 00:28:51 »
Correct AA....doesnt sound the prob to me...
BTW have you had cam sensor prob  :-/ ::) ;D
DaveL
  • Nr. Cupar, Kingdom of Fife
« Reply #10 on: 09 October 2007, 13:12:36 »
Dan
Mine went with the exactly same problem. Had the codes read by local VX and found it was a EGR problem. Have blanked off this with a home made plate, but made too good a job of it. Had to drill a small hole underneath the piston side of the plate. Car responds as it should.
Get the code read and see if it is your cam sensor or some other problem.
hth
DaveL
« Reply #11 on: 09 October 2007, 17:21:56 »
i replaced the cam sensor on mine, problems where:
bad starting when warm, would take lots of cranking. Spanner light would come on.
started it up once, pressed the gas pedal, nothing happened, no revs... no nothing.
Both problems have not come back since the new sensor
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #12 on: 09 October 2007, 17:30:33 »
would a crank sensor really cause that mis fire feeeling when travelling ( for my own info... :-/)
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #13 on: 09 October 2007, 17:39:36 »
That's what we're saying, doesn't sound like the cam or crank sensors.
I like red cars
Markie
« Reply #14 on: 09 October 2007, 17:41:01 »
would a crank sensor really cause that mis fire feeling when travelling ( for my own info... :-/)
gotcha  ;)
Page created in 0.028 seconds with 20 queries.
