Pages: 1 [2] 3  All   Go Down
Author Topic: CAm change and ooops, wat the ****  (Read 7133 times)
The Cambelt Kid
  • Derby
Re: CAm change and ooops, wat the ****
« Reply #15 on: 08 October 2007, 22:35:10 »
Well TB i can only hope as i can imagine bent valves can cost, not to mention the work involved  :'(
I'm just thinking if any other part i came into contact with could cause a knocking niose such as this?
When the car did tick over it sounded fine and didn't sound like it was suffering from low compression.  I take it that if one has low compression the car was idle rough.
Thanks for your help guys, you've really perked me up.  I was about to cry with shame, but now i am working on a plan of attack.
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
« Reply #16 on: 08 October 2007, 22:38:04 »
I suspect the noises are not damage, but something else.  Valves could bend or just get the edge chipped bent, hence reducing compression so it will still run, but noisy. Thats worse case.  Hopefully, the noise is something simpler
The Cambelt Kid
  • Derby
« Reply #17 on: 08 October 2007, 22:45:39 »
Hmmm chip bent!  I didn't think of that one.
This is doing my head in, i'm thinking of all the bad and expensive things that can go wrong...
If lets say it's worst case, how difficult is a head removal and valve replacement?  not to mention cost?
Cheers
M
« Reply #18 on: 09 October 2007, 00:01:47 »
How far did the timing go out when you cranked it by hand? (just re-read. 4 teeth. Enough to cause damage if running but probably not by hand)
I'd say the most likely explanation is that the timing slipped, maybe you got valve to piston contact but it could well be that it just forced some oil out of a hydraulic follower and it's going to be noisy for a few minutes before it fills up.
If it was cranked over by hand a lot before starting it could be that this has just emptied the followers a little.
If you're not positive the timing was right when you put it together take the cam cover off again and double check. Make sure the idlers are torqued correctly, the timing is still OK and the tensioner marks are set correctly for a new belt. Make sure you're using the correctly numbered timing marks for cams 1,2,3 & 4. The latter two are close together on the sprockets and easy to misread. Ensure the tensioner nut is torqued then put it back together and start it again.
On a 2.6 the idler that feeds cams 3 and 4 is not adjustable so the cam timing on these can only be changed in 1 tooth increments. Sounds like it's close enough.
This time, give it a few minutes to warm up and hold it at maybe 2000 rpm for a minute or so assuming it sounds safe to run. Once the lifters have filled up it should quieten.
If not, a compression test should tell if there's any damage done.
Fingers crossed for you :(
« Last Edit: 09 October 2007, 00:06:08 by Kevin_Wood »
« Reply #19 on: 09 October 2007, 00:02:06 »
Cheers
M
Doable, and I have all the kit to do it.
If you're in the sh*te, we'll get you out of it somehow.
I should still also have lots of spare V6 Valves (inc sodium filled exhaust ones fitted to 3.0l) which would be better on LPG (I'd have to confirm they would fit, but don't see why not).
I still think though, that there is a slim to none chance of damage, and this won't have to happen.
I bet you've done something really silly - like not tighten a pulley.
Check the oil level etc.. it may not definately be related..
Matchless
  • Nottingham
    • A white van
« Reply #20 on: 09 October 2007, 09:27:59 »
Still not clear if you ran the engine with the tensioner not set right.
Tentioner was adjusted and torqued before i even put the key in the ignition.
Just to re-clarify, from my understanding, would you agree that it'd take a breaker bar on the crank to bend a valve?
Would take very little to bend a valve, the valves move at 45 degrees to the bore so if contact is made between valve and piston then it is easy to bend the relatively thin valve stem. You only need the valve head to be 0.006" off the seat to spoil engine performance and economy as I found out recently.
Matchless
  • Nottingham
    • A white van
« Reply #21 on: 09 October 2007, 09:36:23 »
I think I would re-check the tensioner adjustment, if it is set too low then it can return to its end-stop as the engine rotates which produces a ticking noise in-time with the engine.
If the noise is more from the top of the engine then I would suspect a noisy injector or a cam follower that has not fully filled with oil yet.
If the tensioner checks out OK then run it to check performance and economy, nois might disapear with use if it is a follower, if it is using more fuel or seems 'flat' then you should measure cylinder compressions and manifold vacuum and post the results.
The Cambelt Kid
  • Derby
« Reply #22 on: 09 October 2007, 10:54:03 »
Nice one chaps, you are pulling me back from the depths of depression here..   :)
When manually cranking over i didn't feel any metal to metal resistance, i only felt compression.  So for the moment i am pinning my hopes on the 'empty lifters' theory, which i did think of first but given the work i had just done on the cambelt i never gave it a second thought.  Thinking about it i did manually crank it over 15+ times as i was being a bit an*l about the timing, so if this would empty the lifters of oil then i do stand a chance.
Having said that TB scared me into thinking that 0.006 of and inch can be a ball ache, so this is on the cards too.  My dad has replaced his head on two of his Volvos (twin cam and single) before so removing the head and replacing valves isn't out of my dad's depth, but it certainly is mine.  I am sure if there is any damage it will be contained to the drivers side head as the passenger was always correct.  I understand that the drivers side head is easier to remove due to the available access.
James - Thanks for the offer of the valves, i understand that they can be costly so if i need them i hope to god the 3.0 ones will fit.  I will sort you out some $$ if it comes to that.  Is it common for all 12 valves in one head to be bent?
« Last Edit: 09 October 2007, 11:02:13 by Omega2000w »
The Cambelt Kid
  • Derby
« Reply #23 on: 09 October 2007, 10:58:23 »
Needless to say i didn't sleep much last night, so all you guys are a ray of bright light to me!  :y
I can LPG a car, change a belt on a 4pot and even change a wheel, but i don't think i can change a V6 timing belt very well  :-[
« Reply #24 on: 09 October 2007, 11:43:05 »
Heres my two peneth....
1) Your followers were slightly noisey when I saw your car teh other day....only slightly.
2) I doubt you have done any valve damage.
3) Let it run for 10-15 minutes and see if it quietens down, I suspect it will because when you turn it over like you did, you can pump some oil out of the followers and they can be noisey for quite a few minutes afterwards and given that yours were very slightly noisey anyway....I feel you have nothing to loose and I suspect its this that you can hear.
The Cambelt Kid
  • Derby
« Reply #25 on: 09 October 2007, 12:09:27 »
I will try that this evening when i return from work and post the results.
Cheers
Marc
Mike Collins
  • North of Bristol
« Reply #26 on: 09 October 2007, 15:55:55 »
If it's any consolation, I lost control of cams 1& 2 when trying to correct the timing during the belt change on my 2.6. After reassembly it most the most awful rattle at first, then went quiet, must have emptied the lifters.
It's worrying for a while, but does not seem to have left a problem, hope yours is similar.
The Cambelt Kid
  • Derby
« Reply #27 on: 09 October 2007, 16:32:23 »
Hi Mike,
I hope so too!  I take it that you manually cranked it over a few times just like i did?
I found it difficult to bring in cams 1+2 so i could lock it because all 4 cams were 1 tooth retarded.  The only adjuster my 2.6 had wasn't making a blind bit of difference...
I'll report back after 7 tonght...
The Cambelt Kid
  • Derby
« Reply #28 on: 09 October 2007, 23:31:26 »
Hi Chaps,
Now this post has been demoted to the second page I thought I’d bring it back to the top...
Since my terrible sleepless night and a day at work not doing any other than worrying about my baby, I arrived home tonight armed with a few ideas as to what was causing my car to rattle like a fraud fiesta.
Some of you mentioned that the noise could have been caused me cranking over the engine by hand far too many times and thus drawing oil out of the lifters.  So the first thing I did when I got home today was start her up and left her on tick over for a few mins, and within the first minute the noises began fade away!  So with the engine still running I topped up the coolant and gave her a few very light blips, working my way up to 2k rpm.  After a few mins at 2k the noise completely disappeared!  Now as you can imagine the smile on my face stretched from Derby to Nottm
I then took her out for a run on the A52 and noticed that it seemed ever so slightly smoother and more responsive.  Also didn't notice any signs of performance loss or any odd noises, which put a little confidence into the work I’d carried out.
So all in all this was a happy ending and I owe all you very kind chaps a very big thank you for all the help and support you have shown.  I was really at the bottom of a hole and you’ve all contributed to pulling me out!  And to think the last thing I would have done is run the car for a few mins, whereas without OOF I would have stripped the front end and maybe even ripped a head off...
Thanking you
Marc
davlad22
  • Sunny Yorkshire
« Reply #29 on: 09 October 2007, 23:44:04 »
Nice one  :y I was just about to have first digs on parts off your car as well  ;D
Pages: 1 [2] 3  All   Go Up
Page created in 0.027 seconds with 21 queries.
