Author Topic: Removing Rear of Headlining - Facelift Saloon  (Read 6440 times)
damon80
  • Wigan
« on: 09 October 2007, 11:17:34 »
Hi Folks,
I've got a 52-plate ex-police MV6.
It currently has a small stubby aerial at the back of the roof, and I want to change this for  beesting aerial.
My question is - how do I go about getting the headlining down a bit at the back so I can get at the fittings that hold the small aerial in place?
Cheers!
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Removing Rear of Headlining - Facelift Saloon
« Reply #1 on: 09 October 2007, 16:41:22 »
bumped to top....
personally when headlining comes off ( albeit in full) its hard to get back on.
I`d expect that its tucked in under the trim above windows with some connectors along it....
Anyone got anything more specific?
Tafty
  • Liverpool
  • This week I am no longer the owner of a miggy!! :(
« Reply #2 on: 09 October 2007, 18:57:11 »
bumped to top....
Agree with you there Markie - I attempted this change of aerial when I first got mine. It caused me so much hassle trying to get at the underside of the existing aerial I gave up and left it as it was.  Although am quite happy at thefact I never changed it now.  Sorry can't be of any help but thought I'd share my experience.
Lee
damon80
  • Wigan
« Reply #3 on: 09 October 2007, 20:04:17 »
Thanks for that folks - much appreciated.  I did manage to get to the back of the aerial earlier though, by gently pulling back the panel that holds the high-level brake light.  Then you can pull the headlining down a bit to get access.
But this leads me to my next question...
The reason why I wanted to change the aerial was because the radio reception was poor.  I have now found the reason for this - the aerial that the car has been fitted with is an after-market one which is at the back of the glove box.
When I've looked at the back of the head unit, there is no other aerial lead (other than the s***e after-market job).
Any ideas where I would find the original aerial???
« Reply #4 on: 09 October 2007, 20:06:46 »
On my elite the stubby aerial is for the telephone (CRT700) and the radio aerial is .. I believe... part of the heated rear windscreen ...
but I'm probably wrong ...  :)
« Reply #5 on: 09 October 2007, 20:24:55 »
Yep. The heated rear window on saloons is used as the radio aerial. There should be a coaxial aerial cable running from the head unit down the driver's side sill panel to a box on the rear parcel shelf which is a preamplifier and splits the radio signal from the heater rear window power supply.
The aerial connector on the rear of the radio frame is known to come loose, giving a rubbish signal.
damon80
  • Wigan
« Reply #6 on: 09 October 2007, 20:40:16 »
Ahh, now this is starting to make a bit more sense now...!
Whereabouts on the rear parcel shelf should the preamp be?  A rough location, and description of what to look for, would be great as I'm not sure if Plod would have ripped it out?
Cheers folks
« Reply #7 on: 09 October 2007, 22:08:09 »
It's under the trim panel but above the metal panel. I'm guessing the trim panel needs to cone out of the interior of the car to get at it.
kevin
davlad22
  • Sunny Yorkshire
« Reply #8 on: 09 October 2007, 23:23:09 »
Possibly, but it might not have been originally supplied with cabling and ancillaries due to lack of headunit. Best of luck getting it sorted, I hate having no radio  ;)
« Reply #9 on: 09 October 2007, 23:49:54 »
If you remove the driver's side kick panel (behind the bonnet release) there should be a connector in the aerial cable here. Could be that it's just the bit from here to the head unit that's missing.
damon80
  • Wigan
« Reply #10 on: 10 October 2007, 13:52:23 »
Thanks - I'll have a gander.
How o you get the drivers side kick panel off?  (I don't want to start ripping panels out gung-ho!  :o )
« Reply #11 on: 10 October 2007, 14:12:29 »
As a first question.
When you look at the ehated rear window elements painted onto the glass......is there two vertical lines that are part of the element about 1/4 of the way in from either side.....?
damon80
  • Wigan
« Reply #12 on: 10 October 2007, 14:28:50 »
Yep, there is indeed 2 vertical lines - is that a good thing or a bad thing?!  :-/
« Reply #13 on: 10 October 2007, 14:33:31 »
Thats good, those lines are the matching strips to support radio receptiona dn obviously the rear window would be the hardest thing to fit.
I suspect you will also find the aerial booster setup under the rear shelf cover to so you would only need a lead to connect it to the radio head unit and thats assuming it doesnt already run to the passnger side foot well (which is where it normaly hides)
davlad22
  • Sunny Yorkshire
« Reply #14 on: 10 October 2007, 14:34:44 »
Not the driver's side then as suggested by kevin?
