Author Topic: 2.5 Gearbox on a 3.0?  (Read 1905 times)
omegalord
« on: 12 October 2007, 14:38:57 »
TB told me a while ago that the 2.5 is about the same on acceleration as the 3.0 due to different gearing.
Is it possible to put the 2.5 box on a 3.0?
If so it should be rapid on acceleration then shouldnt it?
And would the 2.5 box be able to cope with the 3.0 extra power , and poss 250bp if tuned?
Matt
Re: 2.5 Gearbox on a 3.0?
« Reply #1 on: 12 October 2007, 14:41:06 »
Matt
If you are talking the autobox, not a hope in hell.
Also, I believe most of the gearing difference (not all though) is on the diff.
omegalord
« Reply #2 on: 12 October 2007, 14:46:32 »
No im on about a proper manual gearbox.
« Reply #3 on: 12 October 2007, 14:50:01 »
I think the 2.5 manual is rated to 250Nm, the 3.0l manual to 280Nm.  So it depends on torque you are aiming for.
Though I suspect Vx fitted a bigger box to 3.0l for a reason....
omegalord
« Reply #4 on: 12 October 2007, 14:51:51 »
I know its a big job but it would be possible to use the 3.0 bellhousing and put the 2.5 ratios in wouldnt it?
Matt
« Reply #5 on: 12 October 2007, 16:39:30 »
Matt
The bellhousing for both boxes will be the same, it's the internals that will be different.
Martin_1962
« Reply #6 on: 12 October 2007, 18:49:25 »
FInal drive I think
Paul M
  • Edinburgh
« Reply #7 on: 12 October 2007, 20:34:54 »
Both the final drive and gearbox ratios on the 2.5 are different from the 3.0. The actual figures are on autobahnstormers.com
To be honest I don't think it's worth the effort, doing both combined only lowers the ratios about 10% in 5th. Yes the gearing is too high IMO, but the 2.5 isn't that much better. I seem to remember the guy who used to race Omegas on here (can't remember his username  :-[ ) had a significantly higher diff ratio in one, giving a much lower overall ratio. Not sure where he got it though as there isn't much choice for factory Omega diffs and I don't know what else will fit.
