Author Topic: EML on and engine misfiring  (Read 12063 times)
Taxi_Driver
Re: EML on and engine misfiring
« Reply #15 on: 09 October 2007, 21:38:11 »
Don't continue to use the car with a misfire, the unburnt fuel will kill the precious metal in the catalytic converters.
Tests you can do before tech2 -
1) Compression test, get a tester of ebay for a tenner, very easy job. Hope to goodness your compressions are OK though
2) Check connection to the coil per plug pack is OK.
3) Remove the plugs, look for a black one, that will be the cylinder that's not firing.
A failed coil pack may not log a failt code, however using a Tech2 and test plugs, you should be able to identify if there is a strong spark on each plug...
It will.....if its bad enough....occasional miss doesnt....missing for more than about 10secs, EML on and ecu reports a missfire detected  :y
« Reply #16 on: 09 October 2007, 21:41:42 »
DBW engines log a misfire.  Non DBW do not.
Taxi_Driver
« Reply #17 on: 09 October 2007, 21:45:09 »
 :y Alexandjen is a DBW  :y
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #18 on: 10 October 2007, 17:44:34 »
Right quick update  :(
I took all the plugs out today, cleaned and replaced them. Looks like some oil is getting onto the rear two plugs.
Put it all back together and now the car won't even start, just turns over  :o
What could I have done? I only cleaned the plugs  :-?
Did you clean out the dispack, if so, what with?
I like red cars
ians
  • Reading
« Reply #19 on: 10 October 2007, 17:57:59 »
Does it fire at all ? Plug leads in wrong order (on DIS pack or plugs) perhaps?  (not sure if you took them off the dispack)
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #20 on: 10 October 2007, 18:32:20 »
I haven't cleaned the diss pack at all, I did pull the rubber sleeves off the springs and re tensioned them.
It looks like a sealed unit to me.
I regapped the plugs as 3 of them were well over 1mm.
Now it doesn't fire whatsoever and stinks of petrol after turning it over.
Trade club card holder
Code scanner available
« Reply #21 on: 10 October 2007, 18:38:00 »
Silly question .....   you did put the HT leads back on the DIS pack in the right order ... didn't you ??
I would now try removing a plug, connecting to HT lead, grounding the thread and cranking over .. look for a spark at the plug ... as It sounds to me you have no spark from DIS pack .. or spark is occuring at the wrong time  .....
alexandjen
  • The Silver Surfer
« Reply #22 on: 10 October 2007, 18:43:36 »
Is a bit of a silly question  :) as on the 2.2 the plug caps are built onto the diss pack (no leads) and is impossible to get it wrong  ;)
If there is no spark does this point to a faulty diss pack?
Taxi_Driver
« Reply #23 on: 10 October 2007, 19:15:13 »
Not neccesarily......
It could be imobiliser stopping it from starting for example.....but the EML would flash at the same time as cranking....plus i also thinks it shuts the fuel pump off so you wouldnt get a stink of petrol.
Could be a fuse......the big buggars in the engine compartment....check those  :y
My ex veccyB wouldnt start one day.....that was a fuse in the eng compartment for the ECU.....i found that when i tried to read the ecu for what it thought was wrong and i couldnt......obviously as the ecu had no power.
alexandjen
  • The Silver Surfer
« Reply #24 on: 10 October 2007, 19:19:48 »
Would I have to get spare fuses from Vauxhall?  ::)
« Reply #25 on: 10 October 2007, 19:26:00 »
Just to remind peeps, the 2.2 uses a CPP arrangement, so no seperate DIS or HT leads.
Taxi_Driver
« Reply #26 on: 10 October 2007, 19:30:52 »
No....any motoring shop will have them......but just pull em out first to check visually  :y
alexandjen
  • The Silver Surfer
« Reply #27 on: 10 October 2007, 19:35:02 »
Ok thanks, will check them tomorrow.
« Reply #28 on: 10 October 2007, 19:58:44 »
And scrapyards have lots... ...unless Tunnie has been there first ::)
alexandjen
  • The Silver Surfer
« Reply #29 on: 11 October 2007, 17:26:15 »
Right another update.
Code read the car today and it is storing fault code P0320 misfire detected on cylinder 2  :-?
Any further suggestions appreciated
« Last Edit: 11 October 2007, 17:30:30 by alexandjen »
Pages: 1 [2] 3 4  All   Go Up
