Author Topic: Vibrations are now driving me nuts  (Read 3578 times)
« on: 14 October 2007, 15:02:27 »
At 80mph, I'm getting a terrible vibration. I've just spent a good hour at quick fit, all wheels balanced at multiple speeds using the 5-stud method.
Test run up the dual carriageway - problem is still exactly the same.
What else will cause these vibrations, felt through the whole of the car, apart from wheel balancing?
hotel21
  • The Kingdom of Fife
Re: Vibrations are now driving me nuts
« Reply #1 on: 14 October 2007, 15:06:19 »
Buckle on the rim, creating a high spot on the tyre as its now out of round.  Balance weights will balance it within reason but its like driving on an egg shaped tyre....
« Reply #2 on: 14 October 2007, 15:12:28 »
I followed your suggestion, swap the spare (which I also have had balanced!) on each corner, it's not made any difference :(
« Reply #3 on: 14 October 2007, 15:33:28 »
Question - would imbalanced wheels on the rear of the car, cause vibration to be felt through the steering wheel?
sassanach
  • trowbridge
« Reply #4 on: 14 October 2007, 15:35:45 »
propshaft u/j,s  centre bearing of prop breaking up loose bolts on drive shafts/prop shaft etc etc
« Reply #5 on: 14 October 2007, 15:40:25 »
I so hope not...
« Reply #6 on: 14 October 2007, 16:02:08 »
Hi
are your wheels have the original size 5X110 PCD ?
if yes
did they try on car balancing  ?
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #7 on: 14 October 2007, 17:12:40 »
 i too would go with the rubber doughnut at the g/box end of the propshaft. these do fail often. check all universal joints as well. :y
Jaguar XJ6
« Reply #8 on: 14 October 2007, 17:13:46 »
Best way to check? What's acceptable and not acceptable movement?
ffcgary1
  • Mitcham,Surrey.
« Reply #9 on: 14 October 2007, 17:25:57 »
 The rubber coupling just goes soft but there should be no play or movment in the universal joints.  hth.
Jaguar XJ6
ffcgary1
  • Mitcham,Surrey.
« Reply #10 on: 14 October 2007, 17:27:56 »
 Also james, check that the balance weight has not come off the shaft. You will see were it was stuck on if it is missing. :y
Jaguar XJ6
Richard A
  • Aldridge, West Midlands
« Reply #11 on: 14 October 2007, 22:01:22 »
Hello James, I noticed you followed my "wheel Balance" problem, you are also very knowledgeable re Omega's, so I imagine the wheels/tyres were checked for "running true", balancing vibration is speed or revolution sensitive, O to 50 ok 50/55 mph problem, 60 to 75 ok then problem again at 75/80 then again 90ish and so on.
While sorting my car I checked most things, centre propshaft mounting/propshaft balance came into question, to check as a first of, who much vibration can be felt through the gear selector, this can be a tell/tail, worth a check, good luck
best regards
richard
richard a
« Reply #12 on: 14 October 2007, 22:34:27 »
In my experience, propshaft balance tends to make itself known from lower speeds than wheel balance. Wheel balance is rarely a problem under 50/60 MPH but a propshaft out of balance will tend to start from 30/40 MPH due to the faster speed of rotation.Just an observation I've made in the past.
I take it the tyres were checked for bulges?
Does braking have an effect on the vibration?
« Reply #13 on: 14 October 2007, 22:36:15 »
James, this is obviously annoying you, so as a friend, I'll give you £20 for the car ::)
hotel21
« Reply #14 on: 14 October 2007, 22:41:53 »
You really are a tightwad, TB....
I'll make it £35 and I'll throw in a tent and postage....   ;D
