Author Topic: Please please please help me fix...  (Read 4417 times)
Re: Please please please help me fix...
« Reply #15 on: 15 October 2007, 09:47:46 »
Only thing thats springing to mind now, this is probably the newest 2.5 you've worked on the multirams on.  Maybe the ECU is mapped differently, meanin gthe rear doesn't act in same way as earlier ones (eg, it only operates under load).
I need to see if live data monitors the valves....
Wire the solenoid feed up to a little light bulb and poke it out through the front bonnet seal so it sits in front of the windscreen, then go for a drive and see if it lights?
« Reply #16 on: 15 October 2007, 10:25:02 »
Live data does display the valve operation.....it does take one hell of a blip to get the valve to go on the later 2.5's
« Last Edit: 15 October 2007, 10:25:58 by Mark »
« Reply #17 on: 15 October 2007, 13:57:38 »
Ahh.... so it may all be well, then?!
Next step - Drive it with a T2 plugged in?
Under what driving conditions should it open?
