Author Topic: Error codes 1300, 0170 and 0173 on LPG  (Read 4225 times)
The Cambelt Kid
  • Derby
Re: Error codes 1300, 0170 and 0173 on LPG
« Reply #15 on: 15 October 2007, 10:46:23 »
Hmm. Ignitor circuit? Does that mean the feed to the coil pack primaries perhaps?  :-/
Do you pick up the RPM signal for the LPG system from a coil pack feed or from the RPM output onthe petrol ECU?
ECU as per MDTM, the green wire on the lower of the ECU plugs, pin 52 from memory.
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
« Reply #16 on: 15 October 2007, 11:39:46 »
Ahh, OK. Was thinking it was detecting a fault in a circuit, as the description suggests, but if it's only reporting a misfire I guess that's nothing to worry about.
The Cambelt Kid
  • Derby
« Reply #17 on: 15 October 2007, 13:00:00 »
I have just thought of a cunning plan for this little problem.  My old LPG installation switched to LPG at 1700rpm while decelerating; whereas my V6 is 1700 on accelerate.  Maybe I could try changing to decelerate and see if it cures the error.
I never had the problem on my other LPG car and the switchover is transparent!  It’s a piece of cake to change and well worth a try.  Mmm speaking of cake – time for dinner!
Cheers
M
Martin_1962
« Reply #18 on: 15 October 2007, 13:04:15 »
Autos use accelerate, manuals decellerate
The Cambelt Kid
  • Derby
« Reply #19 on: 15 October 2007, 14:10:24 »
With this in mind i have changed the required setting to switch gas on decellerate and reset the ECU errors.  So after a couple of short trips i read the ECU and have no errors (for now!)
The engine does not thump when it switches as it did before!!  :y
