Author Topic: front heated seats  (Read 1465 times)
ghondie
  • sheerness,kent,uk
  • Looking for work, any offers?
front heated seats
« on: 14 October 2007, 21:25:36 »
He all going over my purchase in an anal way, found a dew problems but nothing that i cant deal with. need some advice on how easy it would be to check/remove/replace the heating element on my driver side leather seat.
have repaired one on a saab seat before and that just involved taking the leather skin off and soldering the wire back into place.
with this i obviously have the side airbags, pretensioners etc all in close range.
anybody on here had any dealings with them? would it be worth it just to have a warm rear end on those cold winter or for that matter summer mornings?
regards
nathan
Man with a mission. not sure what it is but i've got one
Sheerness Lifeboat Crew and ILB Mechanic
Re: front heated seats
« Reply #1 on: 14 October 2007, 22:08:14 »
regards
nathan
Heating mats are integral to leather seats. Once you have the cover off the base you'll more than likely find the fault - look for the burnt bit! You might be lucky as I was and get away with cutting a bit of element out & resoldering, but a new mat for the NON leather could always be fitted under the leather, it might take a nadgers longer for heat to reach you nether regions .......  ;D  ;D
« Last Edit: 14 October 2007, 22:08:48 by Andy_B »
ghondie
  • sheerness,kent,uk
« Reply #2 on: 15 October 2007, 13:29:08 »
ok lovely when i get the time after doing bits that need doing sooner rather than later i will have a look
may be a nice easy fix
cheers
nathan
« Reply #3 on: 15 October 2007, 14:55:02 »
cheers
nathan
The worse that can happen is that you end up with a seat that doesn't heat up! Remember to disconnect the battery & leave it few minutes before you remove the seat. It's heavy! :o
