Author Topic: Adjusting Main Beams  (Read 1652 times)
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« on: 15 October 2007, 19:10:46 »
Projector type headlamps
Both Dipped beams set correctly
Both level adjuster servos operating
Problem is that the offside main beam points at the ground a couple of metres ahead of the car, while the nearside main beam lights up the road correctly a long way ahead
Any suggestions as to how the main beam can be adjusted without upsetting the dipped beam allignment or why this situation exists?
IW
hotel21
  • The Kingdom of Fife
Re: Adjusting Main Beams
« Reply #1 on: 15 October 2007, 19:14:37 »
By dipped beams set correctly presume you mean the LHD levers?
Servo's operating as you see the lights moving on bumps?
« Reply #2 on: 15 October 2007, 19:15:19 »
IW
If the dipped is fine, got to be something wrong with main beam, not adjustable on its own.  Double check bulb fitting is correct
« Reply #3 on: 15 October 2007, 19:15:50 »
GLS won't have self levelling ;)
hotel21
« Reply #4 on: 15 October 2007, 19:18:00 »
Well spotted!   ;D
Pitchfork
« Reply #5 on: 15 October 2007, 19:26:51 »
IW
Will do
As the bulbs are tricky to get in I'll remove the whole headlamp just to make sure that it is seating correctly
IW
