Author Topic: Grease/gunge from cambelt top idler  (Read 2244 times)
« on: 15 October 2007, 18:02:24 »
Noticed on my car that the top cambelt idler has got some greasy/gungy stuff coming out of it. Not loads and loads, but it doesn't look great.
Cambelt kit is about half way through it's life, 20k miles.
Yeah yeah, I know. Change it Asap? ;D
    • 530D M Sport, 330i Coupe
Re: Grease/gunge from cambelt top idler
« Reply #1 on: 15 October 2007, 18:20:10 »
Change it as soon as possible!
Serioiusly, if it's losing the lubrication from a moving mechanical part then it won't be long before there's a failure!
« Last Edit: 15 October 2007, 18:22:29 by VXL_V6 »
« Reply #2 on: 15 October 2007, 18:30:09 »
My thoughts too....
« Reply #3 on: 15 October 2007, 19:08:33 »
Not uncommon to see a little bit round there.
The obvious question - why have you got the cambelt cover off again?
JasonH
« Reply #4 on: 15 October 2007, 20:05:37 »
I've noticed that some cambelt followers and tensioners are just well packed with grease, in use some squidges out.
« Reply #5 on: 15 October 2007, 21:03:53 »
Cos it's worrying me....
« Reply #6 on: 15 October 2007, 21:05:40 »
But you can only see by removing cam cover, so my original Q remains. Why remove cam cover?
« Reply #7 on: 15 October 2007, 21:12:33 »
Like I say, it was worrying me. I've done 5,000 miles since we last looked at it, wanted to check again.
I'm just going to have to put a kit on there, me thinks.
« Reply #8 on: 15 October 2007, 21:20:05 »
I thought it was a fairly new kit on there?
Is there any play/wear in the pulleys...
« Reply #9 on: 15 October 2007, 21:30:55 »
Kit's done 20k
Can't really feel for wear, as the belt is on...
« Reply #10 on: 15 October 2007, 21:32:56 »
Kit's done 20k
So it should be fine at least until next summer, depending on your mileage
