Author Topic: Radiator replacement  (Read 2436 times)
amba
  • Medway towns
    • German V6
« on: 15 October 2007, 14:34:50 »
1998 v6 elite...have managed to trace water leak to bottom of coolant radiator just on the seam by the drain plug..now believe only permanent solution is a total radiator replacement...how difficult/easy is this to replace and is there a "how to " or is it pretty much undo and then replace as reverse..any advise would be appreciated
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: Radiator replacement
« Reply #1 on: 15 October 2007, 14:48:56 »
 See the how 2 mate, if your interested i have a rad for sale with the  fan for £35. gen vx.It has been flushed through and there are no leaks. Pm me if your interested.
Jaguar XJ6
amba
  • Medway towns
    • German V6
« Reply #2 on: 15 October 2007, 15:13:44 »
thanks ffcgary1...may take you up on that,just need to check how easy/difficult it is to replace as i am not a mechanic..also unsure if differences between auto and manual ....
« Reply #3 on: 15 October 2007, 15:20:44 »
Auto has a transmission  oil cooler built into its rad, a manual doesn't.
ffcgary1
  • Mitcham,Surrey.
« Reply #4 on: 15 October 2007, 15:31:59 »
You are quite correct, and if the profile had included it was an auto i would have seen that. ::) What is the car mate. man or auto. The rad i have is from a manuel elite.
« Last Edit: 15 October 2007, 15:32:56 by ffcgary1 »
Jaguar XJ6
amba
  • Medway towns
    • German V6
« Reply #5 on: 15 October 2007, 15:38:25 »
hi ffcgary 1...sorry but missed off..mine is 1998 2.5 elite auto..
ffcgary1
  • Mitcham,Surrey.
« Reply #6 on: 15 October 2007, 15:42:54 »
Ok mate sorry i cant help you this time. :(
 please update your profile to include spec: ie auto/man. Best regards, Gary
Jaguar XJ6
« Reply #7 on: 15 October 2007, 17:34:57 »
Its not a bad job to change rad, bit fiddly lifting it out.  You will lose a lot of coolant, and a bit of ATF (so check ATF level after - better still, change it).  You will need 4 new copper washers for the Oil pipes to rad banjos (or reaneal old ones).
« Reply #8 on: 15 October 2007, 17:37:49 »
It's a fair bit easiler on a manual, without the unions to mess with ;D
« Reply #9 on: 15 October 2007, 17:46:51 »
2 extra banjos on auto, else the same...
hotel21
  • The Kingdom of Fife
« Reply #10 on: 15 October 2007, 18:15:24 »
I have a brand new unused gen VX auto rad for sale.  PM if interested, heading south down M6 corridor to London on Saturday so could arrange a meet/handover?
amba
  • Medway towns
    • German V6
« Reply #11 on: 16 October 2007, 09:48:43 »
Thanks Hotel21  pm sent..andrew
amba
  • Medway towns
    • German V6
« Reply #12 on: 16 October 2007, 20:37:16 »
Just wanted to check?is coolant radiator the same for 2.5 as 3.0 on auto elite,and anybody know what part no,s the washers are for banjo bolts on oil cooler pipes as advised these will require replacing,as want to be sure I have all bits before stripping out...antifreeze/radiator/washers..anything else ???
hotel21
« Reply #13 on: 16 October 2007, 21:16:26 »
52463050 is 2.3/3.0 with aircon are same part number at £208 plus VAT retail....
52463046 is 2.5 auto excluding aircon is £224 plus VAT retail....
