Author Topic: Throttle Body Replacement  (Read 1243 times)
moerome
  • Tupelo, Mississippi (USA)
« on: 16 October 2007, 21:55:42 »
Sorry for this long post, but this has been on heck of a saga.
Finally got my ECM for my '99 Catera, installed it (myself), and had it programmed at the dealership out of town.  It was $45.00 after I briefed them how much time it should take for them to program it.  I had insider information courtesy of my newly purchased 2 vol. service manuals.
While driving off the lot, I started experiencing a 'creeping takeoff' which felt like the tranny. It was confirmed with the little ! & Check Engine lights on display. It felt like trying to take off in neutral while in drive (darn automatic trannys). This was also the same symptom I had before replacing the tranny 21 months ago. I turned around and had the mechanic take a look at it. He couldn't find anything outside of the tranny fluid being about a quart low.
Anyhow, the end result is that in order to drive it, I have to shift the tranny like it's a manual.
Question #1:  Programming an ECM shouldn't have an affect on the tranny, would it?!?!?!?!? Also, it's hard to believe that after 21 months (and $2,500.00 later), a tranny would go out like that!!!!!
TWO DAYS LATER.....
I went back to the dealership that intstalled the tranny.  They called me later in the day and said that it wasn't the tranny (?!?!?!?!), but the MAF and throttle body needed to be replaced. They quoted me the following:
PART PART COST LABOR (TIME) TOTAL
Mass Flow Air Sensor $221.69 (part)  $109.50 (1.5 hrs labor); Total $331.19 +tax
Throttle Body $369.64 (part),  $182.50 (2.5 hrs labor); Total $552.14 +tax
Throttel Body Connector $18.95 (part)
GRAND TOTAL -------> $902.28 +tax
I almost laughed in their face!!!! While they were giving me these quotes, my wandered to the Catera forum where I had read someone who had to replace their MAF, and it only took 20 minutes. One and a half hours?!?!??!!!?? What a joke!!!! I was looking in the service manual, and am quite confident that I can install it myself. But at $221.69, I instinctively know that's way too high.
I don't refute that these parts may have to be replaced in that my Catera that has 110,400 miles on it. Plus, I haven't replaced them since I had the car (2001), so I'm sure they need to be swapped out. But not for $900 + !!!!!! That's crazy!!!
ONE DAY LATER..........
Tarried over to AutoZone this afternoon, and had the vehicle scanned.  The following codes came up in order of precedence:
P1890 ------> Tranny
P1280 ------> Fuel Air Metering
P0100 ------> Mass Air Flow Sensor (this code showed up twice)
P1700 ------> Tranny
P1120 ------> Fuel Air Metering
P1220 ------> Fuel Air Metering
P0450 ------> EVAP Emission
P1275 ------> Fuel Air Metering
I went ahead and purchased some throttle body/intake cleaner and blew it out. I followed up on the recommended maintenance post and park the car on an incline (my driveway) facing downward before spraying up in their to avoid seepage going back into the intake.
In the interim, I'm looking at replacing the MAF. GM Direct has it for $115.28 After that, I'll have AutoZone run another scan on it before taking up to the dealership hoping that they will honor the 3 yr/100,000 mi warranty on the tranny. Does any of these other codes like the Fuel Air Metering and EVAP Emission ring a bell? Or, could they be tied to a faulty MAF?
ONE WEEK LATER...........
Received the MAF sensor and the cabin air filter. Replaced both. Timed myself on replacing the MAF and it took about 20-30 minutes to do mainly because I had a little resistance from one of the clamps (a far cry from the 1.5 hours the dealership would've charged me in labor alone).
Anyhow, went back up to AutoZone and had them scan me out. Good news...elminated 5 of the initial 9 error codes. My goal is to get results that only reflect the transmission in order to get the dealership honor their warranty w/o making reference to other problems. Bad news..........still have 4 error codes left. Good news.........2 of the 4 are related to the tranny. Bad news............the other 2 codes consists of the following:
P0450 -- EVAP Emission sensor
P1280 -- Fuel Air Meter
P1700 -- Tranny
P1890 -- Tranny
Can anyone shed light on the EVAP Emission sensor and Fuel Air Meter issues? I would like to resolves these myself before my next showdown with the dealership.
TWO WEEKS LATER.....................................
Okay, I've checked, double checked, and went to about 4 different AutoZone shops and got scanned.  I'm still getting the tranny codes, BUT I'm still getting....
Per suggestions from thE Catera forum, and between trips to the different AutoZone shops, I reseated the fuel cap, and refitted the Mass Air Flow sensor.  Still getting the same readings.  The 'stealership' were still saying (according to their scan) that the throttle body is the culprit.  They wouldn't so much as deal with the tranny codes until they "replaced" the throttle body.
So..........I scouted around until I found a new throttle body for $192.00.  A far cry from the #369.00 + the dealership wanted.  It came with the connector as well (the dealership wanted to sell me that as a separate item).
Even got the gaskets for a little under $6.00 a piece.
Found a place that works strictly on foreign cars and briefed them on my situation.  They said they'd be more than happy to put it on for me (since I discovered in my recent move to this state, I don't have all of my tools), but they said that I would have to get the car reprogrammed again!!!  Oh yeah, they projected a 2 hour job which calculates to be $140.00 in labor.
Does this sound right in having to reprogram the ECM?  Or, should I just go ahead and acquire the tools to do this job myself which I was intended to do in the first place?  Cheers.
markey mark
  • SLady bitshorpe north lincs
Re: Throttle Body Replacement
« Reply #1 on: 16 October 2007, 22:25:58 »
if your throttle body is drive by wire then poss yes have to have it reproggrammed !! if its a normal cable fit it your self bud !!  :y
