Author Topic: water, water everywhere!  (Read 1852 times)
brett1408
  • leamington spa
« on: 17 October 2007, 21:02:05 »
had fun on the way to work this morning, when i switched on the heater fan i got a noise like a bucket of water being stirred very quickly! heat still coming out of the vents though, after a few minutes of this odd noise the passenger footwell filled with water! of course i thought it was the heater matrix gone but no " coolant level low " message on the screen, i stopped over and checked the header tank, level fine, no coolant lost all day so i'm guessing ive got a leak somewhere, it rained very heavy for ages last night but after checking the scuttle area i cant see anything obvious!?! has this happened to anyone else? :o
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: water, water everywhere!
« Reply #1 on: 17 October 2007, 21:08:58 »
Just an idea have you checked the drain holes inside the scuttle panel?
On the passenger side under the bonnet, there is a flap to able you to get at the pollen filter, under there at the very bottom is a rubber drain hole, sometimes they get bloked.. Also there is one one the drivers side but that is easy to see...
« Last Edit: 17 October 2007, 21:11:03 by Loo-knee »
brett1408
  • leamington spa
« Reply #2 on: 17 October 2007, 21:37:45 »
yep, i found them, they're both fine, i'm going to duck-tape the base of the screen for now as the sealing rubber looks very loose, if it works i'll replace it! :)
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #3 on: 17 October 2007, 21:41:26 »
Sounds like you need some "Sikaflex" mate :y
« Reply #4 on: 17 October 2007, 21:50:00 »
Tip a jug of water into passenger side scuttle drain, see how quick it disappears - I reckon your drain is partially bloked, and couldn't cope with the downpour
brett1408
  • leamington spa
« Reply #5 on: 17 October 2007, 22:19:05 »
ty, i'll try it in the morning! it looked quite free though, i'm just so glad that it was'nt the matrix, my first thought, i've just done one on a 306 diesel and that was bad enough!  :y
markey mark
  • SLady bitshorpe north lincs
« Reply #6 on: 17 October 2007, 22:20:28 »
pipes for matrix on omegas are on drivers side bud wet feet you would get  ;D
