Author Topic: tractor with throttle probs !!  (Read 6303 times)
Re: tractor with throttle probs !!
« Reply #15 on: 17 October 2007, 22:28:31 »
This what you after ??  U25D and X25D engines ..
  17  POTENTIOMETER, ACCELERATOR CONTROL, RHD  R1000001- S1156240   90509164 12 37 762 1
  18  POTENTIOMETER, ACCELERATOR CONTROL, RHD  S1156241-                  90512567 12 37 765 1
(I'm still learning how to use EPC !!  )  :)
That'll be the one!
Sxxxxxxx is 95 model year.
markey mark
  • SLady bitshorpe north lincs
« Reply #16 on: 17 October 2007, 22:43:54 »
 cheers entwood mate  :y
markey mark
« Reply #17 on: 17 October 2007, 22:45:42 »
the pot i have has part number 09129106 can you cross ref that entwood please cheers  :y
« Reply #18 on: 17 October 2007, 22:51:19 »
I put that number in the search mode, under part number .. and got "no parts"   but I'm not exactly sure I'm doing it right .. although what I'm doing makes sense, and when I search on the part  no 90509164 it finds it ok ....  :(
Sorry this is not much help :(
edit .. just looking .. part no 09xxxxx ? seems an odd number    I tried 90xxxxx   no good either
« Last Edit: 17 October 2007, 22:53:40 by entwood »
Omegatoy
  • UK
« Reply #19 on: 18 October 2007, 00:21:55 »
right then just bought a tractor and the throttle seems to have a mind of its own !! tends to kanagroo on slight pressure or it goes like the clappers !! once you get over 20mph the cruise control can be used to drive it and it drives spot on any help would be greatly recived cheers  :y
try getting a new fuel filter and filling it with diesel magic, start engine and move throttle up and down to rev engine gently throught the rev range, for a couple of mins , switch off go and have a cup of tea then,(this gives the brew time to really soak in and loosen gum) restart and go for a drive, in 99 percent of cases this will cure the problem in a few it needs to be done twice!!
fault is usually caused  by cheap supermarket fuel gumming up the tracks in the fuel pump pot,worth a try before you go changing things!!!
Omegatoy
markey mark
« Reply #20 on: 18 October 2007, 17:42:34 »
Omegatoy
 cheers for that but what is diesel magic bud ??
« Reply #21 on: 18 October 2007, 21:42:37 »
Diesel magic is an injector cleaner. Supposed to go in tank, but I put it neat in filter (runs bad for a few secs).
The fact that yours is fine on cruise, but bad on pedal makes me think its the sensor.
markey mark
« Reply #22 on: 18 October 2007, 21:54:11 »
yea the guy i got it from regulary changed the oil and fuel filter ecery 5000 miles according to history he gave me with it !"!! :o
« Reply #23 on: 18 October 2007, 22:02:37 »
Oh dear, thats not often enough. 4.5k max...
markey mark
« Reply #24 on: 18 October 2007, 22:04:20 »
bloody hell he would have been doing it once a month  :o :o
« Reply #25 on: 18 October 2007, 22:12:35 »
Thats what happens when you leave BMW to design anything ;)
markey mark
« Reply #26 on: 18 October 2007, 22:14:13 »
are they that bad ??? thought it was a cracking motor  ::)
« Reply #27 on: 18 October 2007, 22:26:24 »
Not the best diesel I'm ever owned, but fairly smooth, reasonably powerful when chipped, but too heavy, too unreliable, and utterly stupidly unbelievable service interval.
But I have some affection for my tractor, despite it giving me 6 months of hell...
