Author Topic: HELP ..CHANGED IGNITION HOUSING AND BARREL  (Read 2087 times)
WILLY
  • birkenhead
« on: 18 October 2007, 19:39:37 »
CHANGED MY 75 YR OLD FATHER INLAWS IGNITION HOUSING AND BARREL ,AFTER IT STUCK SOLID ..COULD NOT TURN KEY AT ALL , STEERING LOCK STUCK ON IN A PAY CAR PARK ..HAD TO SMASH BARREL AND HOUSING OFF TO MOVE CAR ... NOW NOT GETTIN ANY IGNITION DASH LIGHTS
ANY ONE WITH ANY HELP PLEASE...
CHEERS PAUL
vw t4,  tzr 3xv,,rd350r
markey mark
  • SLady bitshorpe north lincs
Re: HELP ..CHANGED IGNITION HOUSING AND BARREL
« Reply #1 on: 18 October 2007, 20:00:29 »
check the wiring plug on rear of barrel bud
WILLY
  • birkenhead
« Reply #2 on: 18 October 2007, 23:39:08 »
 i changed the plug on back  of barrel. seems to fit ok ,and you can here the clicks as you turn the key.still no ignition on dash..but engine cranks!!
saintnick
  • Portsmouth Hampshire
« Reply #3 on: 19 October 2007, 16:37:01 »
did you damage anything when you smashed off the old one??? it wouldnt take much to do some damage to a wire or connection!! or maybe a fuse or fuses have blown?? obvious i know but you never know. HTH
If It aint broke....Lets just dismantle it anyway!
Ken T
  • Stockport
« Reply #4 on: 19 October 2007, 16:43:52 »
It would be handy to know the model and year. On the facelifts, there is a keyreader coil around the key barrel. If this is damaged it wouldn't read the chip in the key, and the imobiliser will kick in and the car will not start, however you would get the dash lights. This needs a Tech 2 to fix. Ugh!
Ken
WILLY
  • birkenhead
« Reply #5 on: 19 October 2007, 19:43:40 »
thanks guys ... its now fixed .. it was the connector on back of housing mark... tried a replacement .and ok
must of been bad connection on pos 2.... thanks every 1 omega 2.5 running good  :y
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #6 on: 20 October 2007, 14:12:50 »
I like red cars
Page created in 0.025 seconds with 20 queries.
