Author Topic: Aaarrrggghh!! Oil filter disaster on 2.6  (Read 7589 times)
HI2DVY
  • Deepest Darkest, Scotland
« on: 17 October 2007, 12:41:50 »
To say I was pi55ed off would be an understatement.
Went out this morning to do a "quick" oil and filter change on my 2.6 V6. I've only had the car a few weeks so this was the first time I'd done it on this one. I've changed the oil several times on the 2.5 so I didnt expect any problems. All was going well until I tried to get the filter housing off. Now these things are only supposed to be torqued to wither 15 or 25 Nm - depending on whather you believe the can itself or the TIS. However this one is rock solid.
There isnt much room for leverage with a ratchet but even so that didnt budge it. I finally got a breaker bar onto it but it still wont move and to make matters worse the oil filter housing has now split with the force I have applied and oil is pi55ing out everywhere... but still it wont come off! >:(
Any suggestions??
Dave
some day.....
HI2DVY
Re: Aaarrrggghh!! Oil filter disaster on 2.6
« Reply #1 on: 17 October 2007, 13:06:57 »
Anybody know what is the correct size socket to remove the filter housing?
some day.....
    • 530D M Sport, 330i Coupe
« Reply #2 on: 17 October 2007, 13:16:58 »
Is this the paper element type which you take the lid off to get too?
HI2DVY
« Reply #3 on: 17 October 2007, 13:20:37 »
Yes. Its just the lid I need off but it wont budge.
some day.....
« Reply #4 on: 17 October 2007, 13:37:15 »
28 rings a bell but not 100%. JamesV6 said that his had a square cut into the hex so a 3/8 ratchet would slot directly on.
I think you can take off the whole housing off which is what it sounds like you are going to have to do and fit a complete new part. MDTM has had to do this on one of his cars so he should be able to advise you better!
HI2DVY
« Reply #5 on: 17 October 2007, 13:43:20 »
Ive been using a 3/8 ratchet in the sqaure hole to try to get this cover off but I think that's what caused it to crack. Think I'll need the proper socket to get it off.
some day.....
« Reply #6 on: 17 October 2007, 13:43:25 »
Yep, a 3/8 ratchet will fit the hole in the end, but it's not going to give you anything like enough torque to help. Don't know about the socket size needed. Sorry. What a pain!
« Reply #7 on: 17 October 2007, 13:48:01 »
Not on mine - the square isn't on mine, wouldn't mind getting a lid that has though as it'd be a dam site easier to get just the wrench in the gap!
There was some talk a while ago about VX doing an adapter plate to allow a standard spin on filter to fit, not sure if a part number ever came to light.
The Cambelt Kid
  • Derby
« Reply #8 on: 17 October 2007, 14:35:58 »
I'm sure i used a 24mm ring spanner last...
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
« Reply #9 on: 17 October 2007, 14:38:40 »
24.... that rings a bell too!!!
ians
  • Reading
« Reply #10 on: 17 October 2007, 14:53:30 »
what a pain - why ever did they do away with the simple spin on ones?
HI2DVY
« Reply #11 on: 17 October 2007, 14:54:07 »
It could well be a 24. I don't have one!
Tried a 1" but its just slightly too large and started to slip. So its time for a trip to the tool shop for a 24mm socket. Wonder what else I'll see when I'm in there. This could be expensive!
Thanks for your help guys  :y
some day.....
« Reply #12 on: 17 October 2007, 15:00:37 »
I find the new sytle filter OK. Done a few oil changes on mine and it has been less hassle than a screw on filter TBH. I wish I could find a position in which I can unscrew it without oil dribbling down my arm.
I think it's probably either leaving them untouched for 20,000 miles - in accordance with the manufacturer's service schedule, or someone having done them up bu66er tight when it says 15nm on the lid that kills them.  Put a socket head on something and the average main dealer technician will go looking for a breaker bar to nip it up with ::)
It winds me up that the filters cost more than the conventional metal ones despite lacking the metal casing though.
HI2DVY
« Reply #13 on: 17 October 2007, 18:12:49 »
Definitely a 24mm socket. Been and bought one. Still needed to lie on my back with both feet on the breaker bar before the barsteward would move though.
Unbelievably, the dealers had a replacement housing cover in stock!! So 2.6 meega back on the road!
Thanks for the advice guys  :y
Dave
some day.....
« Reply #14 on: 17 October 2007, 18:17:11 »
Great News!  :y
Page created in 0.023 seconds with 20 queries.
