Author Topic: max lift cam for v6  (Read 4454 times)
standad
max lift cam for v6
« on: 18 October 2007, 18:44:23 »
as above loolking for oftermarket cam for  2.5 v6 was wondering what is the max cam i can put in this and should i get 4 of the same spec or driffrent ones for the in let and out let thing is i carnt find many places that do them for the v6 so if some one could point me in the right dericton that would be great
thanks mike
__________________
mk3 astra with v power
Re: max lift cam for v6
« Reply #1 on: 18 October 2007, 19:00:48 »
Hi Mike and welcome to the forum :y
You can get good results by fitting cams from a 3.0ltr ;)
markey mark
  • SLady bitshorpe north lincs
« Reply #2 on: 18 October 2007, 20:05:42 »
3.0 ltr cams give about 1mm more lift over standard 2.5 cams bud good for about 20bhp  :y
elvin315
  • Catskill, New York, USA
  • Catera...Cadillac's unloved stepchild.
« Reply #3 on: 18 October 2007, 23:14:32 »
Is that all there is, is that all there is
If that's all there is my friends, then let's keep dancing
Let's break out the booze and have a ball, If that's all there is
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #4 on: 18 October 2007, 23:26:04 »
I HAVE FITTED 3.0LTR CAMS TO MINE AND THEY ARE GOOD FOR ABOUT 20BHP. MAKE S THE CAR FAR MORE FLEXIBLE TO DRIVE. FIT A 4 BAR FUEL PRESSURE REG AS WELL TO IMPROVE THE FLAT SPOT.
« Last Edit: 18 October 2007, 23:26:20 by ffcgary1 »
Jaguar XJ6
Phil B
  • South Wales
« Reply #5 on: 18 October 2007, 23:30:24 »
ffcgary1 where do you get a 4bar regulator from?
Also my real question, rear side window demisters? I am intrigued  :-?
magnul
  • Trondheim, Norway
« Reply #6 on: 18 October 2007, 23:40:54 »
4.0 bar FPR can be found here:
http://www.courtenaysport.co.uk/index.php?act=viewDoc&docId=21
I'm a bit curious whether the FPR is the same for x20xev. Anyone?
Phil B
  • South Wales
« Reply #7 on: 18 October 2007, 23:59:02 »
Oh you bugger, look at all those goodies!
ffcgary1
  • Mitcham,Surrey.
« Reply #8 on: 19 October 2007, 00:11:46 »
 Ebay mate for the 4 bar. about £40. :y
Jaguar XJ6
A380 Elite
  • Ashford, Middx.
« Reply #9 on: 19 October 2007, 06:47:51 »
If only i had some money  :'(
Ok so 3.0 cam into a 2.5 give more bhp.
So 3.2 cam to a 3.0 would give?
Darth Loo-Knee, He The Man
« Reply #10 on: 19 October 2007, 08:04:45 »
They were fitted to earlie Elite's and I have heard that they are sought after by swingers :D
« Reply #11 on: 19 October 2007, 09:16:54 »
And hence why SWMBO wants you to keep the older car and get rid of the new one?
« Reply #12 on: 19 October 2007, 09:19:07 »
Mine does'nt have them, but we just leave the windows open ::)
Rocketman
  • The Netherlands
« Reply #13 on: 19 October 2007, 14:05:33 »
Got my 4 bar FPR from local motor factors. They had to order it though. 60-70 euro (in NL).  But that was before I heard the 3.8 bar from the 2.6 can be had from Vauxhall for half that and is just as good apparently :-/. And, yes it did make a difference for me. :)
standad
« Reply #14 on: 19 October 2007, 20:41:52 »
thanks all for the repleys the set up i have at the min is a 2.5(c25xe) witch i have droped in to my mk3 astra 3.0l tb/ 3.8 fpr from vauxhall 22.58 inc vat xe flywheel /black dimond clutch and f20 box/and a chiped ecu and hpeing to stick it on standalone managemnt (megasquirt) as i no thats the main thing that holds the v6s back well so ive heard ive heard 3.0l cams will be good witch im realy consdering but was just thinking will an after market one will give more or should i just stick a 3.0l one in thanks for reading
Page created in 0.108 seconds with 20 queries.
