Author Topic: bleeding hydraulic clutch  (Read 3028 times)
« on: 22 October 2007, 21:43:03 »
Hi guys,
As you may be aware, my gearbox is currently off, and the hydraulic clutch pipe is disconnected. I'm hoping to refit it all on Wednesday.
Please can someone advise, of the best way to bleed the clutch system?
I am personally thinking, remove the reserviour cap, and force Dot4 through the clutch bleed nipple back up into the tank, but I'd apprecaite an expert opinion, as I've never done this before... :)
Re: bleeding hydraulic clutch
« Reply #1 on: 22 October 2007, 21:55:19 »
Hi guys,
Do a search, its been covered before a few times :)
« Reply #2 on: 22 October 2007, 22:22:56 »
Hi guys,
A different car I know but, when I bled my Astra's clutch I just wedged the pedal down and pressure bled it in the normal way with a Gunson ie from the reservoir out of the nipple. That worked for me.
« Reply #3 on: 22 October 2007, 22:32:12 »
Hi guys,
I know, but the search facility is...  :-X
I use google whenever I search this site  ;D
« Reply #4 on: 22 October 2007, 22:33:59 »
I know, but the search facility is...  :-X .......
Phew! Not just me then!  ::)  ::)  ::)
« Reply #5 on: 22 October 2007, 22:35:58 »
Got it!!!
Remember to pressure fill the clutch hydraulic system by forcing fluid in through the bleed nipple with an easibleed.
I presume, instead of an easibleed, I could just use my hand pump, to force the fluid in?
Matchless
  • Nottingham
    • A white van
« Reply #6 on: 23 October 2007, 11:21:42 »
Best way is to push fluid in through the bleed nipple.
I modified an old easi-bleed, remove the reservoir cap and look for a piece of rubber or silicone hose (tropical fish tank air pipe fits well) that is a tight fit on the nipple and on the easi-bleed pipe.
Use very low air pressure, 10 psi should be enough.
Syringe fluid out of the header tank to make space for new fluid.
Push fluid in through the nipple and take care when you close the nipple otherwise the pipe then blows off and covers you in smelly brake fluid.  ;D
« Reply #7 on: 23 October 2007, 16:44:43 »
Hi guys,
Yup, the search is naff, but using google's site:www.omegaowners.com facility gives a far more powerful search than any application search could manage anyway ;)
Dazzler
  • Haverhill, Suffolk
« Reply #8 on: 23 October 2007, 19:02:09 »
Reverse bleed is the proper way to do it James, so your idea is spot on ;)
STMO123
« Reply #9 on: 23 October 2007, 19:13:03 »
Use a syringe as has been suggested and, if you're stuck for a small diameter hose, strip the wires from inside a cable and use the outer sheath.
« Reply #10 on: 23 October 2007, 19:30:51 »
Cheers guys
One more thing - do I need to do anything with the clutch pedal, in relation to bleeding it?
Dazzler
« Reply #11 on: 23 October 2007, 19:33:16 »
No, pedal should remain in the up (normal) position.
« Reply #12 on: 23 October 2007, 22:34:41 »
As said before I wedged my Astra's clutch down when I bled it. My reasoning was that there wold be less fuid in the system to bleed. It worked for me anyway. :)  :)
« Last Edit: 23 October 2007, 22:35:06 by Andy_B »
Page created in 0.036 seconds with 20 queries.
